Problems with fairchild on 82 ch 717? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Satellite TV
Old 2008-06-13, 08:34 PM   #1
farr38
Default Problems with fairchild on 82 ch 717?
My mother in law is having problems with the odd transponders on 82. Trans 8 has a signal strenght of 75 but Trans 1 has strenght of 50. Check switch is getting an error on odd on 82 on two different sw21's.
Any ideas thanks.
farr38 is offline
Old 2008-06-13, 08:49 PM   #2
i hate tv
I'm guessing that the 82 degree LNB might be failing
Its not uncommon for them to lose signal on odd or even transponders
She should call and book a service call
i hate tv is offline
Old 2008-06-17, 12:11 PM   #3
farr38
Default The LNB failed
I changed the LNB as the old one had a hole in the plastic cover and it is working fine now.
farr38 is offline
