Sony 32HS500 and "PCTV" - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2003
Old 2003-10-28, 09:55 PM   #1
jpaik
Default Sony 32HS500 and "PCTV"
I'm slowly working on a PCTV project, I have the Sony 32HS500; this model's documentation states:
"The DVI-HDTV input terminal is compliant with the EIA-861 standard and is not intended for use with personal computers."
Does this mean that this model is not a candidate for output of digital media from a PC? Are there work-arounds?
I'm in the early stages of figuring all this out, so be patient with me!
Thanks.
J.
Minimum waste, maximum joy
jpaik is offline
Old 2003-11-02, 12:14 PM   #2
billw
Default RE: Sony 32HS500 and "PCTV"
I too have the same TV and never got a clear answer on that. My son even worked for Sony store and he couldn't answer it.
Good Luck
Bill
billw is offline
