#1 | |
A look at the bandwidth crunch in the U.S. that is similar to the pressures facing Canadian providers:
#2 | |
OTA brings you crystal-clear, uncompressed HDTV, no simsubbing, and the real SuperBowl commercials. You can't get all that on satellite... OR CABLE. |
Location: Victoria, BC (on Shaw TV & Internet, Telus home phone, Bell mobile)
And compress the heck out of the MPEG-2 streams, because it is easier/cheaper to provide poor video quality than to upgrade to MPEG-4.
The overcompressed 3 HD or 12 SD per QAM we get now may seem like the good old days in just another year or two.
Mike / technut |
Technut, can you expand/clarify on your post? Specifically the "3 HD or 12 SD per QAM we get now" part.
I am on Rogers (Ontario) and from what I've read here Rogers does not compress their "regular" channels (i.e. whatever they get from the networks is what they send on to the customers). However I am not sure what happens with VoD (or PPV, for that matter). I am assuming that, just like the other channels, Rogers is not altering the signal from the provider, but have no idea what that signal is. Having watched a few high-def movies on-demand I have not been terribly impressed with the extra $2 I'm paying over the standard fee (if it wasn't for the widescreen presentation I probably wouldn't even bother except for a very few, select movies). |
Rogers has floated some trial balloons about deploying real time compression to get more bandwidth. There's a separate thread about it.
They have not yet implemented it but I would't be surprised to see it happen. |
For cable:
1: Upgrade plant to support higher bandwidth. 2: Further segment nodes to allow the same VOD slots for fewer customers, with a net increase of VOD/SDV slots. 3: Put lesser viewed channels on SDV. 4: Possibly change modulation/compression techniques. (Satellite is doing it, but cable has more of a legacy installed base, I suppose). For satellite |
When cable finally cuts analog it will be good for them.
4DTV DSR922 HDD 200 VC 2+ GI2500R VC 2 Pansat 2500a c/ku/dbs feed 10.6ft Clearview mesh AMC-8 to AMC-12 24"Venture. |
This would relieve some of the load: equip Digital OTA tuners into all satellite and cable STBs and design them to kick in when local signals are available and signal the provider's plant not to send those channels. This would work well in Toronto, Montreal, Ottawa, and Vancouver right now and elsewhere in the years to come and especially after the 2011 analogue OTA cutoff. Customers would get a discount on their montly bill for putting up an OTA antenna and thus contributing to lightening the system's load. It would screw up simsubbing though unless it applied only to Canadian stations...
#9 |
stampeder, that would be pretty much impossible since the cable company would then be responsible for the customers OTA equipment, antenna etc. In addition, most customers got cable long ago because of lousy OTA reception so I doubt they would want to go back let alone invest is antenna's etc.
The best way I see to free up bandwidth would be to get rid of all the analog signals.
#10 |
But you know yourself that digital OTA reception is not lousy. It is either full-on glorious or full-off no joy.
Also what I'm envisioning is automatic - if a good enough signal exists, the box tells the plant to stop sending the channel / if it isn't good enough, keep sending it. About equipment responsibility, that's a non-issue. Today if something goes wrong with your HDTV the cable or satellite companies tell you to go get it fixed because it isn't their property or responsibility. Likewise if something goes wrong with your OTA gear (whether its a small indoor antenna on top of the set or a deepest fringe rig on a tower in a rural area) they'd say the same thing and you'd call a service person. I don't see the trouble that you're suggesting. I agree with getting rid of all the analogue channels, BTW. |
#11 | |
Mike / technut |
#12 |
Shaw is an example of how bad it can get. Hopefully they can get there act together and put some efforts into making a lot of systems better/techniques
#13 |
Your suggestions assume the cable companies would actually want the customer to save money...
They could implement a switch system like that, but they sure wouldnt reduce your price. Also, about the cable co's upgrading - hah! That costs money.. its the same reason they throttle now. Its cheaper than actually upgrading their network, and it lets them be the monopoly. Look at Bell - they recently started throttling EVERYONE (there was no current bandwidth crisis, however) - the cost of buying DPI boxes to do this must have been immense. Had they just upgraded their capacity, everyone would be happy. But these boxes give them "ultimate" control. And that = more money. "For only $20 more per month, get full speed, all the time!" I wouldn't be surprised if things like that started up. (The relevance to tv? It is suggested that bell is doing this to start up IPTV) |
#14 |
Classicsat, I like your #3. (3: Put lesser viewed channels on SDV.). It gives a good litmus test of the popularity and future success of certain diginets and if the CRTC lets them abolish genre protection, you'll know which channels will more likely be going through a "rebranding".
MPEG-4 is where it's at and BEV is already doing it with future-ready receivers. Rogers couldn't care less and will cut corners whichever way possible until they're innevitably forced to switch to MPEG-4 and swap out STBs to do so... which is why they're digging their heels in the ground fighting to do (because $$$). Bell has superior technology, yet no encryption security; Rogers the opposite. |
#15 |
Bell has superior technology? That makes me chuckle.
