U.S. DTV News & Discussion - Canadian TV, Computing and Home Theatre Forums
Old 2007-06-18, 05:15 PM   #1
stampeder
Default U.S. DTV News & Discussion
FCC Cites Dell For Failure To Label TV Sets
(Broadcasting & Cable)
Dell.com has joined the list of online TV sales Web sites cited by the FCC for failure to label analog-only TV sets.
As of May 25, sets without digital tuners must be clearly marked, either on the set or in close proximity, with the warning that the set will not receive over-the-air broadcasts after February 2009 unless equipped with a converter box.
http://www.broadcastnewsroom.com/art....jsp?id=152842
stampeder is offline
Old 2007-11-29, 04:09 PM   #2
99gecko
As reprted by Lindsay649 yesterday, Industry Canada has now put out a Consumer Notice.
See post #98 in this thread:
August 31st 2011: Deadline for DTV and HDTV in Canada
99gecko is offline
Old 2008-01-19, 08:42 PM   #3
roger1818
Default FCC List Of Final US DTV assignments
I am surprised no one has posted the link to the FCC's DTV Final Channel Designations yet. It takes a bit of interpretation to read as it uses the station's "Facility ID" instead of its call sign.
roger1818 is offline
Old 2008-02-09, 01:51 PM   #4
stampeder
Default FCC Head Proposes 2012 for LP DTV Cutover in U.S.
Martin is also proposing to help low-power TV stations make the transition to digital more swiftly, including opening up a filing window so that they can apply for DTV licenses. Currently, there is no hard date for the 4,700 low-power stations and translators that will still be allowed to broadcast in analog after the transition, but Martin said he is proposing to make that hard date 2012.
http://www.broadcastnewsroom.com/art....jsp?id=301974
Maybe Vancouver-area folks will finally see some digital LP stations as SeaTac repeaters in Bellingham after all. We can only hope.
LP (low-power) stations in the U.S. are not regular TV stations. They are very local analogue retransmitters of distant Class A or B analogue stations that are not easily received OTA. The difference between an LP station and a simple translator (repeater) is that the operators of LP stations are permitted to simsub their own local commercials over the original ones.
Old 2008-02-10, 01:14 AM   #5
Blackburst
Default LPTV
I think some of these stations will never see the light of day in digital form. Cost of transition will be one. But the other will probably be because their need will be lowered. These new Full Power DT stations can now have their signals travel further and arrive to the viewer in a much better & watchable condition. This will put added pressure on LPTV's. The same I figure will happen to low power translators. The translators will probably be the first to be dropped by most full power stations.
Blackburst is offline
Old 2008-02-10, 10:24 AM   #6
thenewdc
Some of these LP's may just lease some bandwidth on the bigger stations to deliver their service as a sub-channel.
thenewdc is online now
Old 2008-02-25, 04:26 PM   #7
987654321
Default Cleveland and Detroit
Here is the FCC link showing the DTV channel assignments after analog signoff
http://hraunfoss.fcc.gov/edocs_publi...C-07-138A2.pdf
I see that NBC Cleveland has chosen 17 for their DTV feed
and Fox 2 Detroit has chosen ch 7 (they are on 58 now). Does this mean that WXYZ will have to change their logo?
987654321 is offline
Old 2008-02-26, 08:46 AM   #8
crockett18
Default Correct me if I am wrong but
I thought that when the switch over happens a year from now they would broadcast digitally from their primary feed. For example Channel 4 WDIV in Detroit would shut off it's digital channel and broadcast on VHF 4.
crockett18 is offline
Old 2008-02-26, 01:41 PM   #9
LONSat
VHF channels 2 - 6 are not the best for digital broadcast so most stations in that range will either keep their new digital broadcast number 7 to- 5x (whatever the upper limit will be) or an all together different channel number if they are broadcasting on a temporary assignment.
LONSat is online now
Old 2008-02-26, 01:44 PM   #10
stampeder
Yep, there is ongoing debate about the VHF Low band being reassigned, with the Americans wanting to get rid of it for other use and the Canadian broadcasters apparently wanting to keep it for TV. Its still all clear as mud.
So far in Canada the post-2011 TV channel layout is expected to be:
  • 2 through 6 (VHF Low)
  • 7 through 13 (VHF High)
  • 14 through 51 (UHF)
The 52 through 69 channels will be reassigned.
Old 2008-02-26, 11:48 PM   #11
Random Dude
Will the digital signals be a lot stronger after the shut off date? I thought I read somewhere it will be because they wont be needing extra power for analog stations.
Random Dude is offline
Old 2008-02-27, 01:55 AM   #12
stampeder
The ERP (Effective Radiated Power) of a digital OTA station need only be a fraction of the ERP needed by an analogue OTA station to cover the exact same area.
Further energy savings are realized throughout the entire broadcast procedure due to digital OTA's inherent efficiencies.
Digital OTA is better for the environment in many ways.
Old 2008-02-28, 06:02 AM   #13
Random Dude
Okay. Should we be seeing better results after the February 2009 shutoff date?
Old 2008-02-28, 09:56 AM   #14
Tom.F.1
Short answer is YES.
Shutting down the analogs will stop a LOT of the interference we're getting on digital channels.
For instance, I suspect my poor reception some days on WGRZ digital Ch 33, is because of a distant station Ch 33 in Youngstown, Ohio. Since i've already been challenged on this, when the weather gets better, i'll be up on the roof, turning the antenna to see if i can tune in analog 33.
The other issue is the power level of the analogs is so great, most tuners automatically reduce the gain on the input circuits to protect themselves. Our tuners won't be swamped anymore when they shut of analog in less than a year.
Unfortunately, we have to wait a couple more years after that for Canadian analog to go away.
Now, if we could just get digital radio going.......
Samsung TV, Pio-Elite AVR, OppoBD, Wharfedale Speakers, Kicker Subs. Bell EVu, DB-4e OTA:)
Tom.F.1 is offline
Old 2008-02-28, 02:54 PM   #15
recneps77
Originally Posted by Tom.F.1
Now if we could just get digital radio going...
Well then instead of rogers/bell paying places like FS/BB to make us think theres no free HDTV OTA, you'd just have sirius paying people to think theres no free digital radio OTA..
recneps77 is offline
OTA Forum Sponsor
