Samsung A650 Series - Canadian TV, Computing and Home Theatre Forums
Old 2008-04-18, 02:32 AM   #1
williamjsmith
Default Samsung A650 Series
Hey guys, i just replaced my samsung 52 65 a few weeks ago with the new 650 and i have been noticing that my tv just randomly turns off? i think its a reseting issue. Has any one had these problems yet? i had the 65 series for a year with no problems at all. If there are problems which tv would be suggest for me to buy. XBR4?81Series?750?
williamjsmith is offline
Old 2008-04-18, 12:39 PM   #2
fireballz
there is a firmware update on the samsung website that supposedly fixes this issue for your set... you should try and download it and hopefully everything works out. good luck!
fireballz is offline
Old 2008-04-18, 11:05 PM   #3
tijean66
sorry to ask but where is everybody ?? This Tv has been out for one month ? No reviews, nothing here ??
thanks
Sony XBR-55HX929, Bell 9241 PVR, PS3
tijean66 is offline
Old 2008-04-19, 01:59 AM   #4
williamjsmith
Default 52 650
I DONT KNOW, I HAVE BEEN LOOKING FOR REVIEWS EVERYWHERE. SEEMS LIKE NOBODY HAS THE TV YET,Besides the reseting problem i have to say its one of the best tvs i have ever seen. I actually work at best buy and compare them all day and the blacks and colors on the set are insane. The response time is stunning and the automotion is perfect.make video games look insane. The only other tv i have seen this great was the pioneer elite.
Old 2008-04-20, 12:18 PM   #5
tijean66
the problem is gone with the new firmware..... I was shopping for one but every stores I visited, the TV is approx. 1000$ more than in USA ??? It beg the question why ?
tijean66 is offline
Old 2008-04-29, 02:49 AM   #6
gmstuart
I was in Futureshop today and they had just put out the 750 series... mostly same specs as 650 from what I understand... It looked amazing and the colours were beautiful.
I also liked the gloss on the screen... It made the picture more real but wasn't over the top like when they first started having them. I could not notice any real glare in the brightly lit store.
I'm very impressed and will probably be looking at the 650 series this summer... too bad the 52 will be a little big and out of my price range
gmstuart is offline
Old 2008-05-14, 12:01 PM   #7
BOB74
glad to hear the firmware is ok i was looking to buy this or the 7 series this summer too. they look great
BOB74 is offline
Old 2008-05-15, 09:46 AM   #8
protovision
I've been trying to decide between the 52" 650 or 750.
From what I've read, they're pretty much the same panel and features, except the 750 has the DLNA/multimedia features, which does sound interesting, since I have a HTPC setup currently, and would be curious as to how many formats you can stream to the LCD.
I have seen some good examples of the 120hz AMP processing in-store, but I don't know if its something that I'll end up turning off, and should therefore just get a 550/530, and save $$$.
p.
protovision is offline
Old 2008-05-19, 12:53 PM   #9
threeputt
I have been looking at the 750 as well, here is what I found on the differences between the 650 and 750 series. If you have any others or I made a mistake, please add them to the list:
750 has an integrated woofer
16-bit processor vs. 12-bit in 650 (10-bit panel in both)
750 has DLNA features (can stream audio/video/etc. over a home network)
750 can play video off of DLNA/USB flash drive. 650 limited to images/audio
750 comes with 1GB internal flash memory pre-loaded with HD pictures, games, recipes, and a few other things
750 has a square bezel compared to the 650's rounded bezel
750 has a square stand compared to the 650's oval stand
750 stand does not swivel (contrary to Samsung's literature)
threeputt is offline
Old 2008-06-11, 11:21 AM   #10
leoniun
Default Samsung LN52A650 connects Dell D600
I am thinking to buy Samsung LN52A650. however, wondering wether I can use HD15 Male/Male UXGA cable to hook the HDTV with my Dell D600 laptop. I noticed that the TV only D-SUB pc-input and 2 Component input. Which port should I use to connect my laptop and what resolution can I get ?
2) any suggestions on Samsung LN52A650 ?
leoniun is offline
Old 2008-06-11, 06:32 PM   #11
While waiting for a specific response, check out the following thread on HDTVs as PC monitors.
http://www.digitalhome.ca/forum/showthread.php?t=54306
57 is offline
Old 2008-06-12, 09:48 AM   #12
leoniun
Thanks, I am going to get HD15 Male/Male UXGA cable from tigerdirect for $25 and connect it with my samsung. The highest resolution can be 1600X1200.
leoniun is offline
Old 2008-06-12, 09:52 AM   #13
leoniun
got alternative from web. instead of VGA cable, I can use DELL station dock which has DVI output. by using DVI-HDMI cable, I may get better resolution.
leoniun is offline
Old 2008-06-13, 07:50 PM   #14
LCD101
If the video card supports it, VGA can carry full 1920x1080 resolution. You can't do better than that.
I use VGA with 4069 at 1920x1080.
LCD101 is offline
Old 2008-06-13, 10:57 PM   #15
hichael
Smile Samsung NT46A540 VS NT46A650
I want to buy a TV soon. I saw two Samsung models i really liked. 46A540 ($2299) and the other is 46A650 (which is $2799).That is $500 difference between them. Is it worth to pay $500 more just “Motion plus 120Hz”? I know 540 has 35000:1 Contrast ratio and 650 has 50000:1 ratio but i don’t see huge difference on that. I liked the 650 one (the looks), but that doesn’t mean anything to me. My question is.
-Is there any huge performance difference between those two TVs?
-Does 650 worth that much money?
-Does 120Hz make huge difference?
I know i will end up one of these two but don't want to pay $500 just because small difference or am i missing a bigger picture here?.
hichael is offline
Tags
samsung
