Feature Request for Bell Receivers - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Satellite TV
Old 2008-04-12, 03:27 PM   #1
congo
Default Feature Request for Bell Receivers
As the summer repeat season approaches, I'd like to see a feature that would allow me to suspend my timers until the new season. This would be especially useful where I have set a timer to record all episodes.
Panny TC-P60GT50, Bell 9242, Yamaha RX-V730, Paradigm Cinema 70, Harmony One, HTPC
congo is offline
Old 2008-04-12, 04:11 PM   #2
menzel
While this can be implemented, it may be a bit tricky for the consumer, as the networks have been shifting the standard TV season around for years.
menzel is offline
Old 2008-04-12, 06:51 PM   #3
i hate tv
A simple fix
Just have a working EPG, with accurate/correct info in it
Then set the receiver to record all new episodes...
And then I want a pet unicorn
i hate tv is offline
Old 2008-04-12, 06:56 PM   #4
congo
Originally Posted by i hate tv View Post
A simple fix
Exactly the reason most of my "must have" recordings are set to record all episodes. Hence teh request to have a "suspend" option.
congo is offline
Old 2008-04-13, 11:47 AM   #5
i hate tv
I totally agree
My PVR gets filled up too, with shows the wife is afraid to miss....
Its funny how other providers can tell their customers what the original air date is
Maybe someone at expressvu, can use another providers EPG, and then update the ExpressVu EPG to reflect the program info, instead of the old "N/A"
Old 2008-04-13, 11:50 AM   #6
tbusa
it wouldn't take much for this to work. If you noticed, all first run shows (for the most part) has a " new. " in the description. It wouldn't take much for Echostar to get the pvrs to parse this info to detect first run or rerun for the PVR.
tbusa is offline
Old 2008-04-14, 07:26 AM   #7
dosborne
During the summer I usually delete all timers and create new ones for the summer runs.
In the fall the shows you were watching often get moved to a different day/time anyway.
As the schedule is revealed it is easy enough to put them back in.
Although I agree it would be nice to put a show on permanent hold (until you release it) there are lots of reasonable options:
a) delete the timers and recreate when required. Only take s afew seconds to create a timer.
b) let them run anyway, then delete the recorded shows. It may surprise you and grab something you misseed
c) Go through once a week and "ship" the ones you don't want.
dosborne is offline
Old 2008-04-15, 05:02 PM   #8
nicohockey9
What they really need to do is make folders for you same show recordings, and maybe implement some channel icons next to the recordings like Tivo does in Canada and the states.
nicohockey9 is offline
Old 2008-04-15, 05:58 PM   #9
congo
Everybody has some really great ideas but I was just thinking about my original request. If history repeats, every time Bell tries to bring out something new, they end up breaking something else. Maybe my original request might not be such a good thing
Congo
congo is offline
Old 2008-04-15, 06:19 PM   #10
nicohockey9
Usally it isn't Bell that put's out software updates like the one you are requesting... It would be Echostar that would do something like that.
Old 2008-04-15, 07:34 PM   #11
i hate tv
I don't think so nico
It is Echostar hardware, but I believe Bell releases all software upgrades
Old 2008-04-15, 07:52 PM   #12
I_Want_My_HDTV
Cool
That's already available. Just create "new" timers to record new shows only (no reruns.) I would like to see EV make the features they have now work properly before they mess things up even more by adding new ones. (i.e. timers don't work reliably)
I_Want_My_HDTV is offline
Old 2008-04-16, 09:28 PM   #13
nicohockey9
The features in my experience work properly. It's the channels faunlt for not providing proper episode numbers. I think the CRTC needs to make stricter rules for episode numbers provided to the BDU's
Old 2008-04-17, 08:32 PM   #14
I_Want_My_HDTV
Both the broadcasters and EV are at fault. Some broadcasters are bad at providing info. OTOH, publicly available information is often missing from EV's guide or the information is incorrect in EV's guide. Even when the information appears to be correct visually, it often has erroneous NBR info.
Old 2008-04-20, 06:21 PM   #15
jayace
Default New Features
How about a color coded program guide like Shaw.
jayace is offline
