#1 | |
This thread is for discussion of OTA Antenna Modeling Software such as 4NEC2, ezNEC, NEC II, and other such tools.
It is also for sharing ideas and concepts involved in OTA Antenna design. Discussion of the Gray-Hoverman antenna design will remain in its own thread: http://www.digitalhome.ca/forum/showthread.php?t=81982 |
I installed the program, and it looks like its into 3 parts: the program, the build, and the view. Using F1 (help) brings up the message "Cannot find 4nec2.hlp". Is there such a file somewhere ??
Edit: Never mind, found it in the C:\4nec2 directory. |
One project I want to do with the 4nec2 software is make a custom engine that can use both my CPU cores to calculate the NEC output. When it does an analysis now, the task manager show 1 CPU pegged and the other mostly idle.
The custom program will still use the same NEC programs underneath, but split the job into 2 concurrently running instances with staggered frequencies. The output of the two runs will have to be merged into the single output file that 4nec2 expects. |
I'll raise my hand as another person who has downloaded 4nec2 and been able to run basic analysis of the G-H that fits with the expected results. I'm a physicist by training, but software inept so I expect a bit of a learning curve with the modeling programs.
I look forward to contributing ... eventually. Frank |
#7 | |
http://www.digitalhome.ca/forum/show...72&postcount=8 My property has too many tall trees on it so I've never put it up. I've only ever assembled it once for this photo then packed it away again:
Oh... by all means, please get us some dimensions/drawings!!
#9 |
Is anyone interested in modeling/building the old Channel Master Quantum VHF antennas, like the 1110?
#10 |
To go along with the NerdClub objective of "best of the best" hdtv antenna design, some of you might want to give
fractal antenna design a close look. Most fractal antenna design work is being done at very high frequencies, but there are likely lots of UHF-TV possibilities that could be investigated with nec2 modeling analysis !! Here are a couple of links about fractal antennas, to get you started... http://en.wikipedia.org/wiki/Fractal...s_and_fractals http://www.hbci.com/~wenonah/cfa/fractal.htm ...autofils |
#11 |
After examining some pictures and diagrams of old Channel Master Quantum, Channel King and Crossfire VHF antennas, it looks as if the main active elements are for channels 2-6 (and possibly FM), and the little ones between these are for ch. 7-13. Can somebody help me out on this one?
Btw, is anyone willing to draw up their Quantum for me? The fractal antenna design idea looks interesting, but it seems like they'd be pretty big at UHF sizes. |
#12 | |
#13 |
Sweet, thanks! If my assumptions are correct, the 1110 is a 1111 with a few added directors, so it'll be possible to finally model the greatest VHF antenna ever made!!
Next Sunday, I'm going over to a friend's house, and he has a Quantum 1162 or 3 U/V antenna about 10ft above ground (temp install), I'm gonna bring a tape measure and camera. I'll post the results when I get em. |
#14 |
I did a search for CM-1111 and all I could find was a reference to use model 3610, which was called a Crossfire model.
I eventually found a link that described the CrossFire line. The Crossfire antenna line provides high gain across the entire bandwidth. The Crossfire’s performance is attributed to higher proportional energy absorption which means this antenna has more working elements per TV channel, thereby increasing antenna efficiency. When in a weak signal area and a high gain antenna is required, Crossfire is the antenna of choice. Here is the link: http://www.solidsignal.com/channelma...enna_chart.asp If the model 3671 is similar to the 1111, man these are really huge !! Length is 173" or almost 14.5 ft; turning radius of 95.7" Width is 110', due to Ch2; Height is 35.4" due to UHF corner-reflector. They were built to last, with double boom truss construction and reinforced element sleeves for added strength at greatest stress points on long elements and heavy-duty rear elements for greater strength.. Now there is a real-man's DIY and I thought the DBGH was large. You can see the Raw and Net gain for the CM-3671B model at hdtvprimer.com web site "Comparing some commercially available antennas" here: http://www.hdtvprimer.com/ANTENNAS/comparing.html UHF is "O" and VHF is "H". Last edited by Autofils; 2008-04-05 at 09:00 PM. Reason: Added link for CM-3671B VHF-UHF Net Gain by Ken Nist |
#15 |
Hi Folks,
Has anybody tracked down any information about the design of "fractal antenna" beyond the lead that Autofils mentioned last spring? Thank you, DTV Student |
| Bookmarks |
| Tags |
| 4nec2 modeling tips |
| Thread Tools | Search this Thread |
