I just received my new HDTV. I hooked up regular analog cable to the antenna, then connected my digital cable using s-video. When I toggle between the digital and analog signal the analog is much crisper (Global and CNBC are really apparent). Of course I certainly notice a difference when I am actually on one of the digital stations (National Geo, TMN, etc), these look great.
Anyone else see this or is it just me? |
Try using composite video out from your digital terminal. Your TV has a much better comb filter than the terminal has.
Thanks for the advice but unfortunately that didn't workout. I call Rogers, they said the it was a problem with the set top box and would have to fix it. Get this they can't though because they are out of them! Not only are they out of HDTV set top boxes but regular digital ones too! So now I am out of luck until mid next week.
#4 | |
what boxes do they use for just digital? |
Rogers is using Scientific Atlanta for all their boxes.
For HD, it is the 2000HD. For normal Digital Cable, they have the 2000 and 3100. The 3100HD is expected very soon. |
thanks.
another question (i should make another thread, bad me)... what is the menu like on the rogers system? does it compare to the new BEV menu? i hate shaw's menu. it is ugly and 8-bit looking (if you know what i mean). shaw is using Motorolla boxes now. i have no idea what the model is... but they are actually proud of thier new system. i think that satellite runs circles around it IMHO. |
I personally consider the Rogers IPG to be the most superior of all the other provders. Its lightning fast and you can browse a week in advance with Picture in Guide. You can also set your colors for the guides appearance. Its a nifty little feature.
#8 | |
#9 |
My biggest pet peeve about the EPG on Rogers is that it takes a month to scroll the guide from 282 to 3! On Star Choice, when the EPG is on-screen, you can key in a channel number and the guide will reposition itself to begin at that point - makes perfect sense! With Rogers, doing the same thing will change channels - makes no sense!
#10 | |
#11 | |
#12 |
The way the guide works is just a function of software. Maybe another version of software in the future will allow you to jump ahead in the guide without the channel changing with it.
#13 |
travisc, I do this, but it's still way too slow!
#14 | |
#15 |
There are now some post going up on alt.tv.tech.hdtv of others with Toshiba's complaining of the quality of not only digital cable but satillite compared to regular cable.
Anyone else here with a Toshiba notice this??? |
