Call Blocking On Rogers Wireless - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Rogers Communications > Rogers, Fido and Chatr Wireless
Old 2008-02-29, 01:34 PM   #1
FLACer
Post Call Blocking On Rogers Wireless
As someone who has been using the *67 feature for name and number blocking on Rogers Wireless for years, I was surprised to learn when trying to make a call that the *67 command will no longer work to allow you to accomplish this. A recorded message now comes on informing you that to ensure your name and number are blocked you now have to dial #31# before the number you are calling.
I'm wondering if the change from a * prefix to that of a # signifies that Rogers is now starting to charge for this feature on a per call basis (which they shouldn't) as they have apparently started doing with their Home Phone division.
Anyone have any insight on this change as to when it started and what, if anything, it might mean?
FLACer is offline
Old 2008-02-29, 08:06 PM   #2
dcomp11
#31# is the GSM standard for call blocking and has always worked. *67 was basically an override that they had to program into the switch and did not always work properly. It is just easier for them to get rid of the legacy codes.
dcomp11 is offline
Old 2008-02-29, 08:08 PM   #3
Paolo
#31# is actually part of the GSM spec, its been available for YEARS on Rogers and Fido, and Other GSM carriers all over the world. *67 is actually a code that bell canada came up with, and everyone got so used to it, people were complaining before the GSM networks were launched in canada that everyone would forget the new code, so they decided to use the old code as LEGACY. They never advertized *67 or *82, but it was the customers who started telling everyone else to use these codes. The carriers have always told you to use #31# and *31# from day one, not my fault no one pays attention.
Paolo is offline
Old 2008-02-29, 08:37 PM   #4
FLACer
Post
I have been with Rogers Wireless (and its various incarnations) for 16 years and this is the very first time I have ever heard of the code #31# and believe me, I certainly do pay attention. I also don't ever recall them telling me to use this code for call blocking either.
FWIW, I called customer service earlier today and after being transferred to both tech support and their data department, neither one of them had any idea the use of this code had become mandatory on their own network. I also did a search on rogers.com for "#31#" and unless they've added it in the last few hours, nothing tuned up there either. I guess #31# must be a well kept secret at Rogers Wireless.
In any case, thank you both dcomp11 and Paolo for your informative replies.
BTW, and please forgive my ignorance, but what does/did the codes *82 and *31# do?
FLACer is offline
Old 2008-03-01, 12:21 PM   #5
Dr.Dave
I just tried a Google search on Rogers.com and came up with the user guide that was printed in 2005.
It says to use *67 for TDMA and #31# for GSM
Dr.Dave is offline
Old 2008-03-01, 02:53 PM   #6
dcomp11
*82 and *31# force your number to be revealed to person you are calling.
dcomp11 is offline
Old 2008-03-01, 07:04 PM   #7
FLACer
Post
That's interesting Dr. Dave. I just did another search on Rogers Wireless for "call blocking" and this is what came back:
Your search - call blocking - did not match any documents.
No pages were found containing "call blocking".
Suggestions:
* Make sure all words are spelled correctly.
* Try different keywords.
* Try more general keywords.
Huh? What it is I am I doing wrong that is causing these results?
BTW, thanks for the clarification on *82 and *31# dcomp11. I have honestly never seen or heard of these two particular codes before.
FLACer is offline
Old 2008-03-01, 07:56 PM   #8
Paolo
FLACer: try this link: http://shoprogersfaq.custhelp.com/cg...Z2U9MQ**&p_li=
Paolo is offline
Old 2008-03-01, 08:33 PM   #9
FLACer
Post
Thanks Paolo.
Apparently I should have been using the phrase "Name_Display" in my search.
FLACer is offline
Old 2009-06-07, 02:08 AM   #10
IanEck76
Does anyone know if there's a way a rogers wireless user can block incoming SMS messages? I don't mean from "premium" sources, but from someone who I simply don't want texting me.
Thanks in advance.
-Ian.
IanEck76 is offline
Old 2009-06-07, 10:09 AM   #11
99semaj
FWIW, my recollection has always been #31#.
And yes, you can have SMS blocked. Just call Rogers and ask them to put the block on your account. It's an all-or-nothing block, though. I had asked them to just block US/Intl but they couldn't do it.
99semaj is online now
Old 2010-04-20, 01:08 PM   #12
James
so just to be clear here...
I have an iphone, to block a call I type #31 Plus the phone # i want to block?
and there is no charge for this I assume?
James is offline
