Hi Everyone and thank in advance for your help on this one.
I have media center pc that I am using mainly for the pvr feature. I just got MTS Cable and dsl internet. I got Media center to change the channel on the box once but it was really slow so I tried to speed up the IR and now I can’t get it to work again. I have gone through the wizard a hundred times and I am using the MCE remote. What am I doing wrong here? Any help would be great. I have the Motorola RG2200 STB and XP Media center 2005. Thanks Leigh |
Often times the IR controller will be too fast for the STB. Setup will often pick the fast speed. Try a slower speed setting in MCE setup.
thanks for your response. I tryed all three fast medium and slow with no success, any other suggestions?
Quite often you will have to play with the positioning of the IR blaster to get it to be reliable. Once I find the sweet spot, I generally tape it on with electrical tape to eliminate interference (from fluorescent lights, sunlight, etc).
Pete |
