Got The Pioneer 9120, now have questions - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > A/V Receivers and Amplifiers
Old 2008-02-16, 12:02 AM   #1
Rolando
Default Got The Pioneer 9120, now have questions
First off I am happy to finaly get a receiver that can decode Dolby True HD and DTS HD.
Haven't really had time to do much other than hook it up. I tried ONE HD DVD so far. went into setup on my HD-XA2 and set audio to AUTO for HDMI. My 9120 seems to be displaying PCM though even after I selected the Dolby THD track on the 300 HD DVD. Is that normal? does that mean the XA2 is still decoding and sending a 6 track LPCM signal to the receiver?
I checked the setup menu twice on the XA2 and there was no "bitstream" option for HDMI. Am I missing something? ALso the front display on the XA2 shows multi. Shouldn't both the receiver and the player be displaying Dolby true HD?
Rolando Avendaño
Rolando is offline
Old 2008-02-16, 02:31 AM   #2
eightninesuited
Did you update? The player doesn't come with the update.
eightninesuited is offline
Old 2008-02-16, 12:08 PM   #3
Rolando
DOH! How do I check the firmware version? and what is the best way to update? CD or plug a network cable to it?
Rolando Avendaño
Rolando is offline
