AB - Calgary, Lethbridge, Southern Alberta - OTA - Page 78 - Canadian TV, Computing and Home Theatre Forums
Old 2011-08-24, 07:23 PM   #1156
poutanen
querty, if you're using an indoor antenna you might want to try an outdoor mounted in your attic, or even hidden in a closet. I gave up pretty quick on indoor antennas when I found that a 4-bay in the attic could pull in WAY more stations...
poutanen is offline
Old 2011-08-24, 07:33 PM   #1157
Baslim
Trouble is we've only got (and only can get) 6 stations, one of which (CBC French analog 23) has been unusable for the last week. All of those stations are local: my position is 1 mile from CBC/CBCFr, 4 miles from Global/CJIL, 5 miles from CTV and 6 miles from CITY.
Baslim is offline
Old 2011-08-24, 08:26 PM   #1158
querty-m4n
I don't have an attic. I wish I could use a better antenna, but I'm not able to have one. Too small of a room. Thanks for the idea though, as it has come to mind.
The idea was to use my 13 year old 19" CRT in my bedroom so I could catch the local news. I wanted to give away my TV but since it still has some useful life left in it, I thought I might use it for a few more years. Besides, who knows when the cable goes out?
I just checked TVFool and Rabbit Ears site and wasn't surprised that CJIL is a little bit out of my coverage area.
7.1, 10, 13 (13.1 soon) all are coming in very strong in my area at the moment.
Regarding outside antennas, I'm facing the wrong direction. I have to let the signals bounce off of buildings and other structures just to get something. The roof is not inaccessible by myself and other tenants in the building.
querty-m4n is online now
Old 2011-08-24, 11:01 PM   #1159
poutanen
Another thing you might want to try is building yourself a UHF square loop. I've built a few antennas after buying 4 store bought outdoor units, and had great results with homebuilt antennas for specific purposes.
I really wish the CRTC would have a policy similar to the FCC allowing anyone to have an antenna on their roof or apartment/condo roof.
poutanen is offline
Old 2011-08-25, 12:59 PM   #1160
vap57
Location: Mississauga, ON: North of Dundas on west side of Winston Churchill between Laird & Orleans.
querty-m4n, you might want to consider a ClearStream 2. It's designed or outdoor use, but many (including myself) use it as an indoor antenna. It works extremely well. It is compact, to boot.
vap57 is offline
Old 2011-08-25, 02:33 PM   #1161
querty-m4n
From the site:
  • Consistent gain through the entire UHF DTV channel spectrum
  • Totally new engineering for post-2009 UHF DTV frequencies
Only issue is that is a UHF antenna and there's two VHF channels 7 & 13 in my area. I would only receive channel RF 46 with the Colorstream 2.
It is a nice looking antenna. I noticed that it has an option to use a base indoors.
I'll keep my options open. Thanks for the suggestions
^ This is my bedroom TV.
Old 2011-08-25, 02:46 PM   #1162
vap57
qwerty...if you go to the Antennas Direct website, you will find that they now have a CS2 "Complete" that receives VHF. It may work for you. For UHF, it is a powerhouse of an antenna.
vap57 is offline
Old 2011-08-25, 02:49 PM   #1163
querty-m4n
I must have searched for the wrong one. Oops. Thanks for re-directing me.
Old 2011-08-25, 06:51 PM   #1164
msharp
Default Calgary (Hidden Valley)
Okay I live in Hidden Valley in Calgary and when I hook my antenna (it is a cheep one) up to my HDTV and do a scan for OTA channels all I can get is CTV analog. Zero digital channels
Am I just in a reception shadow area from Nose Hill park or am I doing something wrong? Would a $100 antenna solve my problems. I did make an antenna from a YouTube how to video and had the same results as my other store bought antenna.
msharp is offline
Old 2011-08-25, 08:30 PM   #1165
frontpl8
maybe try punching in your address in to tv fool and see what it gives you. If your using an indoor antenna it might not be getting a signal, you may need to try moving it to different locations to see if that helps, ie near a window, and maybe higher up.Also the antenna must be capable of recieving UHF channels. If its just plain rabbit ears it probably won't work since all digital channels in Calgary are broadcasting on UHF frequencies.
frontpl8 is offline
Old 2011-08-25, 08:52 PM   #1166
msharp
Just found TV Fool and it does show me in a signal week area because of a hill between me and the TV tower. I guess I'll have to get something on the larger size to stick in my attic.
msharp is offline
Old 2011-08-25, 10:36 PM   #1167
andrela
msharp: Would you like to post the link to your TVfool result? There are some of the most knowledgeable users on the forum that may be able to help in your setup. Hidden Valley area may be almost impossible to get a signal depending where you are located (TVfool link does not provide your personal info.)
andrela is online now
Old 2011-08-26, 03:12 AM   #1168
downbeat
@msharp: Welcome to the forum.
Apart from using tvfool.com to share some useful info, as other members has suggested, do take a moment to see these helpful instruction for new members.
http://www.digitalhome.ca/forum/showthread.php?t=125161
That will help you provide us with the right info so we can all help you better.
downbeat is online now
Old 2011-08-26, 01:13 PM   #1169
Billsmith
msharp - what is the nearest intersection to your location. This will help us to determine what TVfool predicts?
Billsmith is offline
Old 2011-08-26, 09:55 PM   #1170
msharp
I am close to Hidden Valley Dr. and Shaganappi
these are my results
http://www.tvfool.com/?option=com_wr...9e74cc5a57710d
msharp is offline
OTA Forum Sponsor
