Hey guys very new to this fourm looking for a little help here I have the the Denon 988 and a set of energy RC70 my front is also a energy Large. In my options I have it set to large , the problem is when watching movies or playing games in Dolby pro logic it sounds very muffled from the front.
Thanks any help would be good shane |
Are you using a sub? If so then your speakers should be set to "small". But the main question is how do you have your components hooked up to your AVR? What do you have hooked up?
