Good receiver for the PS3? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > A/V Receivers and Amplifiers
Old 2008-02-14, 04:03 PM   #1
mpivovar
Default Good receiver for the PS3?
So does a receiver to go with the PS3 have to be able to decode the new codecs. I understand that it decodes them internally and sends the audio as PCM. So will any reciever that accepts PCM over HDMI be good. Or do I need to get one like the Onkyo 605. What recievers ou there are a good match for the PS3? Thanks for the help.
mpivovar is offline
Old 2008-02-14, 04:12 PM   #2
ClgShaft
is the digital deals section, there is mention the sony strdg 910 is a very good compliment to the ps3, and it is currently on sale.
hope this helps you out.
ClgShaft is offline
Old 2008-02-14, 04:32 PM   #3
hugh
No. Any receiver will work with the PS3. Obviously you will need optical in or HDMI in for digital transfer.
There are no best receivers for the PS3.
hugh is offline
Old 2008-02-14, 04:35 PM   #4
TECHNOKID
However, am I correct to assume that HDMI or optical is a must as the BluRay would downscale video otherwise, am I correct?
TECHNOKID is offline
Old 2008-02-14, 04:40 PM   #5
hugh
Optical only carries audio. The HDMI can go to your set, it doesn't have to go to a receiver.
Folks can correct me if I am wrong, but you can use component cables with the PS3.
hugh is offline
Old 2008-02-14, 04:52 PM   #6
Although you can use component video cables, the PS3 will not upconvert SD DVDs to HD formats over component, only via HDMI.
Regarding the lossless HD audio formats, I don't believe they can be sent via optical or coaxial audio connections, only DD5.1 and DTS.
You may wish to look at the following regarding AVR features:
http://www.digitalhome.ca/forum/showthread.php?t=76082
57 is offline
Old 2008-02-14, 08:02 PM   #7
TECHNOKID
OK, I was correct in my assumption and if you want the HD you must use HDMI. You are talking specifically about the PS3, am I correct to assume the HDMI ruling also applies to stand alone units?
Old 2008-02-14, 10:32 PM   #8
Any current consumer upconverting player or HD-DVD player will only upconvert SD-DVDs via HDMI. A while back there were a couple of upconverting DVD players that, with a hack, could upconvert via component video. They are no longer available, except used.
HD-DVD players can send 720P/1080i via component video, which seems counter-intuitive (until ICT takes effect, which may never happen).
57 is offline
Old 2008-02-19, 11:29 AM   #9
mpivovar
So essentially want a reciever that will pass the 1080P video through to my TV and one that can take in the PCM audio via the HDMI. Is this correct??? Do all revievers read the PCM audio that is sent by the PS3?
mpivovar is offline
Old 2008-02-22, 01:32 PM   #10
polaris
Any entry level model should be able to handle PCM. HDMI seems the best way to output audio from the PS3 to ensure you really get the best quality.
polaris is offline
Old 2008-02-22, 01:45 PM   #11
Luis_A51
A very good option is the Sony STR-DG910
It handles 7.1PCM, 24hz playback and of course 1080p - everything the PS3 has to offer. Oh and it has 3 HDMI inputs and transcoding to HDMI.
Everything you need, for a good price (about $300-400)
Sony KDS-60A2000, Sony Playstation 1/2/3 (60gig) and PSP, Sony STR-DG910, Pioneer/Sony 7.1, 39 PS3 Games, 120 BR movies
Luis_A51 is offline
Old 2008-02-25, 11:35 AM   #12
mpivovar
Thanks that is the reciever I was leaning towards. And fits my budget so a little more money can be spent on the speakers.
mpivovar is offline
