30HF83 VPOS Service Code? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2003
Old 2003-09-15, 10:20 PM   #1
JOVO
Default 30HF83 VPOS Service Code?
I need to adjust the vertical positioning for my 30HF83 but I don't see a VPOS code in the Service Menu while pressing the Channel UP/DOWN button. Does anyone know if this code exists and if it does how I can access it?
Thanks.
JOVO is offline
Old 2003-09-16, 11:39 AM   #2
JohnnyG
VPS or VPS2 or something like that.
JohnnyG is offline
Old 2003-09-16, 11:37 PM   #3
JOVO
Thanks for the tip JohnnyG. I discovered that I just had to scroll the channel DOWN button for a bit longer or use the UP button instead to get there faster. The code was VPS1 and the setting was way off. I had to change it from 88H to 80H.
JOVO is offline
