#256 |
Hi Pinza,
Tried both suggestions but got the same result. I noted that only odd transponders worked, which led me to look at cabling. I found out that the 6131's in-wall cabling included a non-DPP "splitter". I removed it and everything works fine now! I now have my neighbor's older 5900 to validate when he comes back but I assume it will be similar. I would like to thank you for your help on this. I wish I can contribute to this forum in the same way now. ;-) |
#257 |
Hello
I'm trying to setup 3 bell satelite receivers at my parents place with a dpp44 switch. [I currently have a dpp44 switch setup and working in my own house running 2 6131 and 1 4100 receivers] and everything works fine. My issue here is I'm trying to setup a 9241 and 2 4100 receivers and the 9241 receiver [after running the check switch] fails to pick up satelite 82. this is my current setup - dual LNB used on sateliete - 2 cables running from satelite to dpp44 switch - power connected - 1 cable from the dpp44 switch to a dp plus separator #123254 then 2 cables from the separator to the 9241 receiver Can someone help me and let me know if I have something setup incorrectly. The satelite picks up both 91 and 82 satelites when the dpp44 switch is not used but when I hook up the dpp44 switch, the 9241 receiver loses the 82 satelite Thanks |
#258 |
Hello again
I have solved my problem. There was a bad connection in my setup but now everything is working DeeV |
#259 |
Just wondering if a power inserter would help or hinder the signal on a DPP LNB.
Thanks |
#260 |
Hinder or blow the LNB.
#261 |
Jumping Jack, just what are you trying to achieve.?
First you ask about using 2 Dish's now adding a Power Inserter to a DPP LNBF..... What problems are you experiencing.? In Georgetown, as I said in the other thread you started, a std 20" (51cm) Dish should be fine, if aligned correctly. |
#262 |
I'm not having any problems. I had a new dish installed by bell and since the installer put up a DPP, I wasn't sure if I needed to remove the existing power inserter.
Pinza, I am a bit obsessed with signal strength. It might come from using OTA in the past. |
#263 | |
#264 |
coming to Bell October 23rd
#265 |
I trust you my friend but until I see them in a warehouse....... Well you know the rest.....lol
If they do appear, it is about time....... |
#266 |
#267 |
Good day all,
Just need to confirm that I'm on the right path, I currently have a dish pro plus LNB (2 outputs and one input) connected to 2 lines coming into the house running to 2- 9241 receives with seperators on the back going from the one line to the 2 inputs on the receivers, all works great both 91 and 82 come in strong, I'm now in the process of adding a 3rd 9241, I installed a DPP 44 P/N:173405 switch, ran the 2 lines from the LNB to the switch, connect the power inserter to line 1 input, connect the 3 lines from the DPP 44 output to the seperators then to the 9241 receivers. I seem to beable to only pick up 91 on any of the receivers and not 82 at all. Run checkswitch and it goes through 38 steps instead of the 5 and comes up telling me that if i save i will have less channels than I currently do, any thoughts, bad swithc or power inserter?? thanks for any suggestions stef |
#268 |
#269 |
Pinza,
I did have the power inserter on port 1 output and I also the the receivers hook up to the bottom outputs as well, that's why I kinda suppect a bad switch or power inserter |
#270 |
Well I would double check the cable/connectors between the Power Inserter and Port 1 again, if they are OK, then it would suggest the Power Inserter or the switch.
| Tags |
| dpp, dpp44, separator |
