#61 |
Hey thanks for the Assistance the Centre Pin was too short I went and got one specially cut today put in on and ran a check switch test and it read the SW44 Switch right away! Thanks again for everyones help!
#62 |
This is a very helpful thread!
Here's what I want to do but I haven't been able to find an example for it yet. I want to connect 2 dual LNBs (91 and 82), and combine them with a digital cable feed to feed 3 receivers in the house. I want to avoid running a 2nd coax to the receivers since all my connctions are in the basement. I know I can run one coax combining sat and cable with a couple of diplexers, but I'm throwing anther LNB into the mix and not sure if it can be done. One coax carrying 91, 82 and cable? Here's what I think I need.... -two SW34 - giving me four 91 and four 82 outputs -SW21s to combine 1 output from each sw34 -diplexer to split the sat and cable signals. <--this is where I get stuck. Where does the diplexer go? Every sketch I make I seem to think I need to run another coax line for the cable. |
#63 |
Couldn't you just Diplex in before the SW44 on any cable, then pull out the Cable feed via a Diplexer at any of the receivers.? Never tried this but I think it makes sense.
#64 |
cordoba002,
As suggested above I would use a SW44 switch if you are using more than 2 satellite receivers. Link from a knowledgeable member about OTA passthrough being no problem through the SW44 switch. |
#65 |
Thanks guys. Is this what you mean? I drew it up.
#66 |
I'm new to the satellite thing but some what familiar with A/V distribution but with regular cable. I have a bell dish running to a SW44 to four receivers. What I'm wondering is can I swap the switch to something that I can "inject" a modulated signal in. Such as a Leviton 5x8 Multi-Switch
#67 |
Why not use the drawing above and Diplex in the modulated signals.?
I do not believe there is a 5 x 8 switch that works with Bell TV. |
#68 |
So just moved into my house..
Panasonic PT-AE4000|Pioneer VSX-1021K|Energy Connoisseur CF-50, CC-10, CB-10, Velodyne VDR-12|Sony BDP-S350|Roku XS 2|Telus CIS430|Harmony One LG 55LE5500|H\K AVR 347|Yamaha NS-8390|Polk Audio PSW-10|Samsung BD-P1600|Roku 2 XS|Telus CIS330|Harmony 600 LG 42LC7D|Roku 2 XS|Telus CIS330|Harmony 600 LG 32LS3400|Telus CIS330 |
#69 |
No, there is NO receiver that supplies power to an SW44 or SW64 for that matter, that is why these switch's all ship with a Power Supply and a Power Inserter.
Dish Pro is a totally different kettle of Fish. |
#70 |
Ic.. so because of DP Quad was DP, the internal switch in the lnb worked just fine. Bassically if I went on ebay and picked up a DP or DPP 44.. would it be the same isuse?
#71 |
DP & DPP LNBF's get power from the receivers if connected directly without switch's.
I believe that a DP34 also gets it's power from the receivers. DPP44's also require a power inserter. |
#72 |
It is too bad the bell only supplies sw44 switch made by echostar I wish it used the dishpro plus sw44 model would be awesome and make installations a lot less complicated when using more than 4 recievers. The way the installers install them is mind boggling and time consuming but it does work the way they do it. With the upgraded dishpro equipment would make their jobs much easier. Maybe echostar does not want to sell or share its stuff?
#73 |
Think about it logically;
Dish Pro LNBF's, would cost way more. Dish Pro Plus LNBF's, would cost way more. Dish Pro switch's, would cost way more. Dish Pro Plus Switch's, would cost way more. Dish Pro Plus Seperators would be required, therefore extra costs. Obtaining a licence to use DP & DPP, would incur extra costs. Who picks up the extra costs involved. Bell TV. Whereas with Legacy Equipment; LNBF's cost pennies. SW21's are cheap. SW44's are cheap. (Lots are refurbs). Extra Cable is required. Extra Connectors are required. Who save money, Bell TV. It is the Installer or Installation Company that has to pay for the extra Cable and Connectors. It is Win Win for Bell TV, it costs them less and the fact it costs the Installers more is not their problem, they get a fixed price per job anyway. Most Installers would love to see Dish Pro (Plus) but I think if it happens it will be a long way away. They talked about implementing DP/DPP 4 years ago, the Techs are still waiting. If they ever bring in DP/DPP, you can be almost gauranteed that the rates to the installers will drop, again. |
#74 |
well if Nimiq 5 @ 72 comes online in a couple years.. they will need to consider it.. unless theres a way to do it legacy?? would it be using a SW21 to combine the signal from 72 with 82\91 comming out of the SW44??
If it is that.. I'll be picking up a DPP34 on ebay.. no way ill have that much crap installed on the backboard to feed some receivers..
#75 |
you should put the diplexer after output 1 on the sw44,, not before the input of the dish.
| Tags |
| belltv, multiswitch, newbie, sw44 |
