SW44 switch discussion - Canadian TV, Computing and Home Theatre Forums
Old 2008-01-22, 10:16 AM   #1
Q
Default SW44 switch discussion
Another very common installation is the SW44 switch. It typically uses two inputs from 82 and 2 inputs from 91 which will allow 4 outputs but can also be used with 2 inputs from one sat to output 4 lines like a SW24. This switch also requires a power adaptor to be used.
Some people have said it works without a power adaptor but I personally would not recommend it because your receivers will then need to power the switch and lnb's.
It is an indoor and outdoor switch however needs to be plugged indoors.
Last edited by Q; 2008-02-25 at 02:16 PM. Reason: Changed wording to allow only 2 lines input
Q is offline
Old 2008-01-23, 09:44 AM   #2
hugh
Administrators Note:
I want to thank Q for all his work setting these threads. All of the work below was done by him. I merely helped him post some of this information (hence why it appears to be posted by me). Please direct any thanks or questions to him - Hugh
hugh is offline
Old 2008-01-23, 09:44 AM   #3
hugh
Typical install with one dish.
hugh is offline
Old 2008-01-23, 09:44 AM   #4
hugh
or with two dishes.
hugh is offline
Old 2008-02-13, 01:04 PM   #5
Oswald13
Default 2nd request for help with SW44 switch
Hi,
I cannot get my 2nd tuner (on my new 9242) to work with the switch. Tuner one works fine, and when I bypass the switch, I can acquire a signal with tuner 2 (so I know it is not the receiver). I have disconnected the receiver from the switch, run the check switch test, then reconnected the receiver and still cannot pass the check switch test for the 2nd tuner. Is there anything else that I could be missing, other than the obvious (bad switch)? I have searched through this forum and found some ideas (e.g., the notion of disconnnecting the receiver and running the switch test again), but I would appreciate any additional help.
Thanks!
Oswald13 is offline
Old 2008-02-13, 01:54 PM   #6
Jaygeetee
DHC Supporter
Have you swapped coaxes between tuners 1 and 2 to see if problem follows the cables?
Jaygeetee is online now
Old 2008-02-13, 02:06 PM   #7
Oswald13
Sounds like an idea--should I run a check switch test with the receiver disconnected again, before I switch the lines?
Oswald13 is offline
Old 2008-02-13, 03:15 PM   #8
Jaygeetee
DHC Supporter
Both tuners must have cables connected to do a check switch test. Swap the two tuner cables then go to point dish menu and see which tuner is or is not functioning. If tuner 1 is now o/s the problem is that cable going to sw44. Do check switch again just to confirm.
Old 2008-02-16, 07:39 PM   #9
loftaone
Default SW44 upgrade
I currently have 1 dish with dual LNB's and 2 sw21 switches.. I am thinking of getting a 3rd receiver...what to I need? I am thinking a sw44? any help is appreciated.
Cheers
loftaone is offline
Old 2008-02-16, 09:28 PM   #10
kandkt
Yes, a SW44 will do the trick as it will provide 4 outputs. Keep in mind that any dual tuner receivers required 2 outputs, but in your case it doesn't look like you have any dual tuners.
http://www.digitalhome.ca/forum/showthread.php?t=79117
kandkt is offline
Old 2008-02-17, 09:19 AM   #11
loftaone
Default SW44 switch
Thanks for the reply. Can I just install the sw44 inside using the 2 lines from the dish after my 2 sw21's. Or do I have to remove them? Thanks in advance.
loftaone is offline
Old 2008-02-17, 09:44 AM   #12
kandkt
You need to remove the SW21's. You will need to feed the two feeds from sat 91 LNB to input 1A and 1B on the switch and the two feeds from sat 82 LNB to 2A and 2B. The switch needs all four inputs to work correctly.
kandkt is offline
Old 2008-02-19, 08:07 AM   #13
dosborne
Although I prefer mounting the switch inside, you can also consider replacing the SW21s with the SW44 at the dish. Then run a third line to the location of your third receiver. This is a less flexible option, but may be easier and less expensive for you.
dosborne is offline
Old 2008-02-19, 10:48 PM   #14
klystron
Cheers
Another way to get outputs for 3 receivers is a Dishpro Plus 1000.2 setup. I recently installed one and it works great. They are about $60 on ebay and have the switch integrated into the lnb.
klystron is offline
Old 2008-02-20, 07:39 AM   #15
dosborne
Keep in mind though that you can't mix legacy and DPP technology in your setup and that DPP is not officially supported by Bell. Running a single wire would seem to be more appropriate and cheaper in this case and would also use supported equipment.
dosborne is offline
Tags
belltv, multiswitch, newbie, sw44
