IR Cable - Canadian TV, Computing and Home Theatre Forums
Old 2008-01-07, 09:41 PM   #1
lecoyte
Default IR Cable
I have a rogers 8300HD box. I want to push it into the basement, connecting to it via an HDMI cable and an IR cable.
Where is the best place to buy an IR cable from ? Do they come with Receivers / Emitters or do you buy them separately ?
What is the better brand to buy ?
Thanks.
lecoyte is offline
Old 2008-01-08, 12:11 AM   #2
Here's a thread on IR Repeaters - not sure if that's what you want.
http://www.digitalhome.ca/forum/showthread.php?t=61930
Regarding HDMI, have you checked it out in the current position? There are lots of HDMI issues and there's no guarantee that it'll work. See:
http://www.digitalhome.ca/forum/showthread.php?t=71112
57 is offline
Old 2008-01-08, 06:28 AM   #3
congo
I've not seen great results with those RF repeaters, at least the Radio Shack variety.
I cam across a unit that uses your existing coax wiring to transmit the signals. I haven't found any write ups though but the concept is interesting. This assumes you have a coax connection available at the TV and where you are putting the receiver.
http://www.mxmart.com/index.php?main...roducts_id=128
Congo
Panny TC-P60GT50, Bell 9242, Yamaha RX-V730, Paradigm Cinema 70, Harmony One, HTPC
congo is offline
Old 2008-01-08, 08:29 AM   #4
lecoyte
Default IR Cable
In terms of the request. All that i want is an IR receiver and Transmitter and the able that connects them. I just don't know where to get them. I don't want to do this wirelessly. I don't want IR to RF conversion.
On the back of the 8300 box, there is an input for "IR". What plugs in to that ?
Thanks.
lecoyte is offline
Old 2008-01-08, 09:20 AM   #5
classicsat
More than likely, it is an output for an IR blaster to control a VCR. Some Pace boxes have an IR input, AFAIK.
classicsat is online now
Old 2008-01-08, 10:02 AM   #6
As mentioned above, it's a VCR Commander port - an output, not an input.
57 is offline
Old 2008-01-08, 07:32 PM   #7
lecoyte
Default ir input
ok. thanks for that. that makes sense.
lecoyte is offline
Old 2008-01-08, 08:36 PM   #8
i hate tv
I guess so, but it makes me wonder how many people hook up their VCR's to their HD boxes
Logic would tell me that the same amount would want the setup you have lecoyte, so why not go high tech with extra ports, instead of low tech?
Just my .02
i hate tv is offline
Old 2008-01-12, 03:57 PM   #9
lecoyte
Just my .02
Sorry, what do you mean by extra ports ?
I think that I have found what I need. This has the description of "hidden ir system" on a site called "smarthome". This seems to be what I need.
lecoyte is offline
