Tripp Lite Surge Suppressor - Canadian TV, Computing and Home Theatre Forums
Old 2008-01-02, 12:54 AM   #1
smaron345
Default Tripp Lite Surge Suppressor
I am looking to purchase the Tripp Lite HT810ISOCTR Surge Suppressor.
Does anyone have anything negative to say about this product?
I am also wondering where I can purchase this brand in Western Canada?
Thanks in Advance,
smaron345 is offline
Old 2008-01-02, 01:53 AM   #2
timbo
Hi, welcome to the forum.
I've only heard good things about Tripp Lite from our fellow DHC'ers.
The tripp lite website has a link to buying in other countries (Canada included, of course).
I'm sure someone here at Digital Home has shopped for Tripp Lite in western Canada and will be able to make a recommendation, however, it would be helpful to know where you are located.
Will you please add your location to your user profile? It helps others to help you better.
timbo is offline
Old 2008-01-02, 05:24 PM   #3
johnp'in'bc
smaron345 ..... cendirect (dot) com .... I have purchased several Tripp Lite products from them.
I just took at peak at their site, and they have the product you are looking for.
johnp'in'bc is offline
Old 2008-01-27, 07:55 PM   #4
smaron345
Thanks for the info!!!
