Toronto/Buffalo OTA channels after 2009 and then 2011 (closed) - Page 3 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Over-The-Air (OTA) Digital Television > OTA Station & Network Operational Status
Closed Thread
Old 2008-01-18, 09:35 AM   #31
videobruce
Has 57 always been directional, or is this somewhat recent??
How about 20 or 30 years ago??
videobruce is offline
Old 2008-01-18, 07:14 PM   #32
rob50312
I think City -tv Toronto has always been a little directional.Videobruce can you not even receive their analog signal.Rich from RW antenna he reports fine reception of 57 and 53 from WNY.
CM 4248 at Buffalo,XG43 at Toronto,M4 at Buffalo,CH 11 yagi at Ham.
rob50312 is offline
Old 2008-01-18, 08:13 PM   #33
jimdoo
Default City
The reason he gets it i'm sure is because of the 40' or so tower he has and the huge parabolic antenna setup - I'm sure this helps with the reception
jimdoo is offline
Old 2008-01-18, 10:25 PM   #34
rob50312
Jimdoo he also reported reception with using winegard Yagi 9032 either at home or his office cannot remember which on a 40 foot tower.
rob50312 is offline
Old 2008-01-19, 12:17 PM   #35
videobruce
rob50312; I always used 57 as a reference. 30 or so years ago I could barely receive it (with a smaller all band antenna and no amp). It was barely there, usually all I would see were the vertical blanking interval when it wouldn't lock. Now, I can see the image, but I wouldn't consider it watchable in any sense if the word. It is the weakest of any station that I can receive from Ontario. 52 is the next weakest.
Should read; "fine reception from Niagara county". He is 20 miles closer.
Ok, how about ch. 52? Slightly stronger signal, but still not really watchable.
Old 2008-01-19, 06:46 PM   #36
rob50312
Sun analog 52 is a much weaker transmitter but not directional.52 at 30kw from FCP building.While City analog is >310kw at the top of CN tower.So it must be the directional antenna that makes it weaker.I think those antenna pattern pictures are very misleading as to reception areas with directional transmitters.
rob50312 is offline
Old 2008-01-19, 08:42 PM   #37
roger1818
I am surprised no one has posted the link to the FCC's DTV Final Channel Designations in this thread yet. It takes a bit of interpretation to read as it uses the station's "Facility ID" instead of its call sign, but from it you can see that in 2009:
  • WUTV-DT will remain on 14
  • WNYB-DT will revert to 26
  • WNLO-DT will remain on 32
  • WGRZ-DT will remain on 33
  • WNYO-DT will remain on 34
  • WKBW-DT will remain on 38
  • WIVB-DT will remain on 39
  • WNED-DT will remain on 43
  • WNGS-DT will start transmitting on 7
  • WPXJ-DT will start transmitting on 23
roger1818 is online now
Old 2008-01-20, 01:03 AM   #38
Tom.F.1
thanx Rogers, thats a cool link.
Think you can find a canadian link for the same info for TO stations?
Samsung TV, Pio-Elite AVR, OppoBD, Wharfedale Speakers, Kicker Subs. Bell EVu, DB-4e OTA:)
Tom.F.1 is offline
Old 2008-01-20, 09:49 AM   #39
videobruce
Actual 7.1, or where they are now 38.2 (7.2)?
Someone better tell them about it since I just talked to their chief engineer and he doesn't know about any final decision whether it will be 51 or 23.
BTW, that link failed (typical for the FCC).
Old 2008-01-20, 10:05 AM   #40
dsspredator
Link works:
http://fjallfoss.fcc.gov/edocs_publi...C-07-138A2.pdf
WHEC ROCHESTER (DT 10) will only be 5.9kW. That sucks.
dsspredator is offline
Old 2008-01-20, 12:29 PM   #41
videobruce
Not here. Just hangs on a blank screen.
Old 2008-01-20, 04:58 PM   #42
roger1818
I don't think IC has published that information yet. I susspect we won't see it until sometime in 2009 (a guess on my part).
WPXJ-DT will be broadcasting at 174-180 MHz which is reffered to as channel 7 in North America. I don't know what channel it will be remapped to but my guess is 51-1.
My guess is it is an issue with the plug-in for Acrobat Reader on you computer.
Old 2008-01-21, 09:25 AM   #43
videobruce
I use FoxIt reader. I tried the link with Firefox and it did open. Another one of many reasons why I almost never use that damn FCC site.
Anyway, I do see that WPXJ is allocated to 23 and WNGS is allocated to ch. 7. Again, no one over at WPXJ seems to know this.
More amazing that there will be one VHF station left when the dust settles. I find it hard to believe some UHF allocation couldn't be found for WNGS.
Now, I would immediately think that WNGS would then use WKBW's old xmitter since it solves two issues. It gets rid of WKBWs' old equipment and it gets WNGS a instant VHF facility.
BUT, my main questioin would be, since they (WNGS) are piggybacked on WKBWs' ch. 38 signal, why can't they just remain that way? Why a separate xmitter?? Just blow off VHF 7 and keep things as is?
Old 2008-01-21, 09:34 AM   #44
videobruce
roger1818; Looking over that database without any legend, as usual (see previous comments about the FCC), what does that last collumn refer to?
That collumn for population makes no sense either. If you look at the numbers for WIVB & WKBW (xmitters 2 miles apart) there is a 300,000 difference in the counts.
Old 2008-01-21, 10:35 AM   #45
thenewdc
Piggybacking WNGS on 7-2 makes it readily available in Southern Ontario, but moving to ch-7 may make it less easily receivable. I hope it stays on 7-2. Of course I could always use my FTA to receive it.
thenewdc is offline
Closed Thread
