Can you add WIFI or GPS to a PDA? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Portable Electronics: Digital Cameras, Camcorders, ebook Readers, iPods, MP3 Players and GPS
Old 2007-12-20, 09:02 PM   #1
ipassgas1
Default Can you add WIFI or GPS to a PDA?
I'd like to buy a telus PDA with one of their promotion plans. Trouble is, I can't find one with both GPS and WIFI. Does anyone know if it's possible to add WIFI and/or GPS to a PDA via the SD slot or by some other way?
Any suggestions? I really don't need the data plan if I can somehow get WiFi. My work and home both have wireless connections.
Thanks in advance.
Mark
ipassgas1 is offline
Old 2007-12-21, 02:29 AM   #2
clomas
You can get a Palm wifi card that fits in the SD slot. They seem to work very well. A colleague uses this to get online at home and at work. If the PDA has bluetooth you can probably get a bluetooth GPS puck. I have one from TomTom that I use with my Nokia. I think Palm also has a GPS that fits in the SD slot.
clomas is offline
