Sound card suggestion - Canadian TV, Computing and Home Theatre Forums
Old 2007-12-06, 07:00 AM   #1
Rideauman
Default Sound card suggestion
Hello:
I currently have an older model Dell computer hooked up to my AVR (Yamaha RXV459) to play music only - no video requirement at all. The existing sound card is a SB Live! Value model. Needless to say, the sound quality is pretty crappy. I have it hooked up with an analogue connection (split for left and right).
What is your suggestion for a better sound card? If I change the connection to digital (i.e. coax - the only open digital connection I have left on the AVR), will I get better sound quality? Note that I'm playing 2-channel music only - I don't have a requirement for 5.1 playback. I've seen the suggestions for the Chaintech AV-710 - however, the issues surrounding the driver availability and only an optical connection (see comment above) concern me.
Any suggestions would be greatly appreciated.
Rideauman is offline
Old 2007-12-06, 07:40 AM   #2
hugh
I would certainly try the digital connection first to see if it meets your needs. I have the Inferno card from Sondigo and can recommend it. And its a Canadian company!
hugh is offline
Old 2007-12-06, 12:55 PM   #3
Rideauman
From what I see, it looks like your Sondigo card has analog and optical connections. I'm looking for something that has digital coax output. Or do I not understand what s/pdif connections are?
Old 2007-12-06, 11:45 PM   #4
I_Want_My_HDTV
S/PDIF is 75 ohm coax digital audio. IIRC, the Chaintech AV-710 has S/PDIF out as well as TOSLink. The drivers are not great but do the job. The SoundBlaster Audigy 2 OEM is similar in price and quality to the AV-710 but I find the extra driver features not that useful and it only has S/PDIF. All you really need for digital audio is a working digital output with pass through for DD/DTS sources. Newer HD audio sources will change that, of course, but then you are getting into a whole new class of system. I wouldn't spend too much money on an audio card. The onboard HD audio on new motherboards with will perform as well as many audio cards when used with a digital connection.
I_Want_My_HDTV is offline
Old 2007-12-09, 12:31 AM   #5
Rideauman
Thanks for the feedback - perhaps I'll give the Chaintech hardware a try.
Old 2007-12-10, 09:34 AM   #6
slyboy
I purchased the Chaintech AV710 recently. It does not have digital coax, only optical toslink for digitial connections. If you don't have a digital audio output on your computer I can recommend this card as an inexpensive option. The software drivers are ok, not great, but if you're just looking to get a digital stream out of your PC over to a home theatre setup (for example) then this card will work.
Pioneer Elite PRO-730HD | Elite DV-59AVi | Marantz SR8200 | Mirage OM series | Rogers/Cisco 8642HD, SA4250HD
slyboy is offline
Old 2007-12-10, 05:28 PM   #7
I_Want_My_HDTV
You are right. My mistake. The SB Audigy 2 OEM definitely has coax audio and is about equal to the AV-710 in quality and price. I've connected it to my A/V receiver and it works well with digital. I also have an AV710 but haven't used it with digital out (quite obviously.)
Old 2007-12-13, 01:12 PM   #8
Rideauman
HDTV, where can I even see one of these Audigy 2 OEM cards? I went on the Soundblaster site and the only Audigy 2 model they have are external units.
Old 2007-12-13, 04:11 PM   #9
I_Want_My_HDTV
Check ncix.com for "Creative Sound Blaster Audigy SE". They appear to be limited in availability these days.
