In need of camcorder advice! - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Portable Electronics: Digital Cameras, Camcorders, ebook Readers, iPods, MP3 Players and GPS
Old 2007-11-24, 12:18 PM   #1
adam3039
Default In need of camcorder advice!
I am looking to buy a camcorder to convert some of my old vhs tapes to dvd's. So I need somthing with a AV input, and of course the firewire DV output. We went out and bought the canon zr800 only to find out that it is incapable to converting AV-DV. Is there any camcorders around the 200-300$ range that can do what i need?
Thanks alot
Adam
adam3039 is offline
Old 2007-11-24, 05:59 PM   #2
sugarman
Adam,
Not sure if you are talking camcorder or standard VCR tapes, but anyway...
You can copy analog camcorder tapes using AV cables to a standalone DVD recorder. I've done this with an old 8MM camcorder & for freinds who didn't have the proper DV firewire cable for my recorder.
Same for standard VCR tapes. And there are dual play DVD/VHS combo recorders like Samsungs DVD-VR350. Might be better if you have a lot of tapes to convert.
OR,
If you have a PC DVD burner, you could use an analog capture card. This will also let you do editing.
http://www.microsoft.com/windowsxp/u...video.mspx#EEG
I guess you can also find a computer/AV place that will do this for you.
sugarman is offline
Old 2007-11-25, 02:30 AM   #3
adam3039
Im sorry, I should have specified heh. I actually have a mac, so I have the firewire cable that will go straight from the DV out into my mac, I want to do it that way so I can dump it all on to my computer and edit the things out that arn't necessary heh. So basically i just need a camcorder that is capable of converting video signals, I could go get a bridge, but i figured why get a bridge when some camcorders will do it for you, and then ill have a camcorder to tape some events.
In terms of tapes, I have some of those old old tapes that go into the VHS Adapter and into a vcr.
adam3039 is offline
Old 2007-11-25, 12:08 PM   #4
sugarman
Ah, Ok, So you have a working VHS camcorder. I don't know of a camcorder that does converting & I don't have a mac. Must be an app for a capture device that will let you direct input analog video. You might get a better answer over on the mac site. For the old video I've saved to disc I was burning everything. Figured I could always edit later on my pc using Roxio.
sugarman is offline
Old 2007-12-05, 10:35 AM   #5
gordonb
My Canon ZR300 comes with a cable for A/V input that can, according to the manual, be used for capture via DV over firewire. I haven't tried it as I have capture cards to get video into my computer. The newer Canon DV camcorders don't appear to let you dub from an AV input to a DV output.
gordonb is offline
