BellTV Remotes: Issues, Discussion, Programming, etc. - Page 23 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Satellite TV
Old 2012-06-13, 08:44 PM   #331
schlep
deleted
schlep is offline
Old 2012-06-14, 06:52 AM   #332
schlep
deleted
schlep is offline
Old 2012-06-14, 06:54 AM   #333
schlep
There are 3 screens in this category and I do not see anywhere that it lists remote. Am I in the correct place.
Will this stop the other bell remote from working?
schlep is offline
Old 2012-06-14, 07:23 AM   #334
Pinza
Should be there in Section (i) alternate way to get to Sys Info is MENU, 6, 1, 3.
You would need them all set to the same Remote Address, so first thing to know, is what the existing one is set to, which should be visible on that System Info Screen. Then you will need to set the new Remote to that address.
Is the new remote a direct replacement for the old ones or is it a different model.?
Pinza is offline
Old 2012-06-14, 08:11 AM   #335
schlep
The old remote is still in use, I wanted to have 2 remotes control the same tv and receiver. Is it possible? FYI thanks for the help
schlep is offline
Old 2012-06-14, 09:01 AM   #336
jdevlin
Try this.
On the existing remote press and hold the sat button until the other buttons come on. Then let go. The sat should flash. Press the # twice. The sat button should flash the current code of the remote.
On the new remote press and hold the sat button until the light come on then let go. Now type in the two digit code you got from the original remote. ex 02, 11 etc. Then press the # once. Your remotes are now set to the same code.
The 9241 should accept two different remotes if one is IR and the other is UHF.
The screen you want should look something like this except for BELL instead of DISH.
jdevlin is offline
Old 2012-06-14, 10:27 AM   #337
Alekss
I just want to post an update on my situation, and hopefully this will help someone else with similar issues:
TV: 2011 Samsung 530 Series 59" Plazma
Receiver: Bell HD 6400
Remote: 5.4 IR
Problem: Could not get remote to work properly. TV functions (volume, power buttons) would work fine, but any receiver functions (Guide , select, browse, themes, etc. etc. buttons) would often stop working.
Solutions that worked for me:
In TV menu, go to MODE, then CELL LIGHT, then I changed it from 7 to 5.
So far no issues.
Alekss is offline
Old 2012-06-14, 11:29 AM   #338
schlep
You rock thanks so much, it is working.
schlep is offline
Old 2012-06-15, 07:02 PM   #339
willyone
Default digital/optical cable
I just got my 9241 Wed. and the tech set it up with standard cables. He recommended that I would get better sound if I used a digital optical cable to my Sony Home Theatre system. I installed one. I also changed the standard cables and connected the TV to the receiver with an HDMI cable. My problem is the Bell remote turns the TV on ok but does not control the volume and I have to use the remote for the Home Theater system. What can I do to get the Bell remote to control the volume as well.
(before I just needed to have the home theatre turned on and when I used the bell remote it controlled the volume. Now it doesn't) Did I take one too many cables away?)
willyone
willyone is offline
Old 2012-07-23, 10:14 PM   #340
superskid
So I have my blue 9200 remote control setup to control my satellite receiver and LG TV. I have recently hooked up my LG TV to a soundbar so don't use the built in TV speakers anymore. Is there anyway to have the remote control the soundbar for volume, but the TV for input etc..
superskid is offline
Old 2012-07-23, 10:31 PM   #341
CentaurChester
Hello
You'd have to program the AUX to control the volume for the sound bar.
Should be able find how re-program your remote control at the very begin (page 1) to show you how re-program for AUX, or check the link below for
info on how to.. I know bit different then say for TV button..
You should be able get the correct codes and -how to- from here...
http://support.bell.ca/TV/Receivers/...ver_user_guide
If you newer remote try 9241 info ( IR /UHF pro )
If you can not get to work with Sound bar, You may have go buy all in one remote.. I had planned on buying one for my Telus/bell 9241 but I finally
found a code that work proper with my LG TV..
Hope that helps some, Good Luck.
-Chester
LG 42LD520 42" 1080p,Telus 9241, Yamaha HTR-5250,Xbox 360s,ps3,Asus N617Jq 4gb Win 7 64bit
CentaurChester is offline
Old 2012-08-01, 10:08 PM   #342
mcfilmmakers
Default Remote keeps forgetting it is programmed
I've had my satellite for 2 years. Suddenly, over the past week, I find myself having to program my remote every time I want to turn the tv on/off.
Thing is, the remote seems to forget randomly.
Ex: I come home from work. The Bell remote won't turn on my TV. I turn my TV on with my TV remote. All satellite functions work fine but the Bell remote won't adjust the volume or turn off the TV. I program the Bell remote. The Bell remote now adjusts the volume and turns off the tv. The Bell remote turns on the TV. I flip the channels, pick a show and watch it. An hour later, I can't adjust the volume or turn off the TV. Rinse and repeat.
Does anyone know why this is happening?
mcfilmmakers is offline
Old 2012-08-01, 11:41 PM   #343
Batteries weak? IR interference - link below?
http://www.digitalhome.ca/forum/showthread.php?t=64463
57 is offline
Old 2012-08-02, 07:35 PM   #344
mcfilmmakers
It can't be IR interference, it's been the same TV for 2 years.
How can it be a weak battery issue if the satellite functions don't have such an issue?
Changing the batteries doesn't fix the problem anyway.
Old 2012-08-02, 08:32 PM   #345
Things change. Firmware changes the IR sensitivity of the STB and things go bonkers. The STB or TV is moved slightly, the issue is not the TV - perhaps another device like CFLs, or the sun, etc. You decide if you wish to follow up - suggest you at least check out the thread since there are a lot of possibilities outside of the TV. Just a couple of suggestions.
Could be a bad remote. Do you have another remote you can try?
57 is offline
