BEV for Condos, IR Blaster and DVD recorder - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Fibe TV
Old 2007-10-29, 12:14 PM   #1
richard061458
Default BEV for Condos, IR Blaster and DVD recorder
My VCR just went kerflooie (sp?) so I figured it was time to upgrade to a DVD recorder.
Since I use an IR blaster connected to my Motorola RG2400 STB to control the recorder, I called Bell tech support to find out if the STB will work with a DVD recorder. First he said yes, then he said maybe then he checked with someone else and said no.
I don't think they really know.
Someone here must know if I can use a DVD recorder with my setup.
If the answer is yes, step by step configuration instructions would be appreciated.
richard061458 is offline
Old 2007-10-29, 10:13 PM   #2
merve04
well my best guess is whats the brand of your recorder,, and then look in your bev manual and try those codes in the receiver. if your recoder is a one button record and stop,, well theres a chance ill work,, its a matter if the code is there for your recorder.
merve04 is offline
Old 2007-10-30, 09:17 AM   #3
cascarbob
My parents have the same set up and I was tempted to pick one up with a hard drive for them for Christmas but all this uncertainty scares me.
Bell has put up a dish on the roof for impatient HD clients so they don't lose them to Rogers but they get a pretty decent channel package from Bell included in their condo fee without setting up a separate account just to rent a PVR.
My suggestion to them will be to wait it out till the technology catches up.
cascarbob is offline
Old 2007-10-30, 06:42 PM   #4
merve04
I wish my condo was like that,, they seem to cheap to have HD in this building, there saying ill cost 25 000 dollars, yes 3 zeros,, i cant belive that figure,, theres 96 units in between 2 buildings. I'm sure i could put up some flebay parts and make it happen for alot less.
merve04 is offline
