Aastra 390 Screenphone from Bell - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Canada Home Phone and Internet
Old 2007-09-27, 08:13 PM   #1
Sniper18
Default Aastra 390 Screenphone from Bell
Hi all;
I bought a Aastra 390 screenphone from bell late last year. I love the phone, but *hate* the fact it is always advertising **** to me on the main screen when the phone is not in use (advertising its i-select options). I didn't buy the phone for it to put advertising in my kitchen. I have tried several things to remove this without any luck.
The first thing I tried was to reset the phone to it's factory defaults. I did this by setting the date to Jan 1 12:00am and then selecting "options" then "mute" then "#". At first I thought this worked. It completely wiped my phone (including my phone book). But then a message came up saying "for FREE services press OK" and it wont go away.
Do you think bell will have any idea what I am talking about if I call them? Do you think they will be able to help?
Sniper18 is offline
Old 2008-07-15, 11:28 AM   #2
Sniper18
After almost a year of painfully watching those ad's on my phone, I think I have found the answer.
Bellow you will find a list of phone numbers to call from your Vista phone that will allow you to perform various functions. These phones are configured via scripts that are downloaded from a server. By calling a specific host server you can gain access to hidden functions. The only trick is to know what server to call for what function. I tried asking Bell for a list of numbers but they will only give them out on a need-to-know basis. Therefore I'm compiling the following list. If you have any of these numbers please e-mail them to me.
Initial configuration: 1-877-2-473-5328
Remove ads (a.k.a. "What's New"): 1-877-434-4442
Config. / change financial services: 1-888-419-1717
Voice mail interaction w/ the screen: 1-877-611-1010
Interactive i-Select e-Support: 1-888-673-7222
Source: http://aetherworks.ca:8080/pages/ref_vista.html.
It was also mentioned in the comments of this page: http://sensorymetrics.com/2006/11/08...birth-of-saas/
I have yet to try it, but if it doesnt work I will revise this post
Sniper18 is offline
Old 2008-07-16, 08:18 AM   #3
Sniper18
I have tried it and it worked. No more ad's on my phone
Sniper18 is offline
Old 2008-07-16, 09:44 AM   #4
hugh
Thanks for keeping us posted. I'm certain your posts will help others with this device who are annoyed by the ads!
hugh is offline
Old 2009-01-14, 05:56 PM   #5
mrrogers22
Default Aastra 390
Hello sniper18
thank you for all your help and the great information. I have a 390 that was previously used. This had a company name on the screen that i could never remove. I followed your directions and it is now cleared.
Many thanks to you.
mrrogers22 is offline
Old 2009-01-14, 08:34 PM   #6
Sniper18
MrRogers22;
I am glad this information was of use to you. The one thing I have noticed though is after a power outage or anything like that, the ads will come back (not sure if this will be the case with the company info that was on your phone). I have solved this problem by saving the 'no-ads' phone number in my phone book on the phone and whenever they reappear (after power outages) I simply dial the number and they go away.
Sniper18 is offline
Old 2009-01-21, 06:41 AM   #7
mrrogers22
Hello Sniper18,
Thank you for all your help. The number that you speak of that you saved on your phone. 'no-ads' Is it the you had listed?
I tried this number to remove the screen name from a second 390 phone that I have. I got a message that the number is not accessable from my area. I am in South Florida. Do you now of a different number that I could try?
Thank you again
Old 2009-02-02, 09:04 PM   #8
richm
Bell has discontinued their process to wipe out the ad. Aastra Telecom manufactures this phone and has a 9 step procedure to clear the Bell I-Select Advertisement. Herre's a copy:
WARNING: This procedure will permanently erase the Callers List and Directory in your 390 telephone. Please record important names and numbers before implementing this procedure. This procedure disables the programming of the idle screen, so it will not only get rid of the ads permenately but you will also lose the ability to program any of the softkeys on the idle screen as well.
1) Press the Options button (the short button below the orange Goodbye button)
2) Press the Down Arrow 4 times or until the cursor points to Area Code and press Show
3) Press the Down Arrow 2 times or until it points to entry 3.
4) Press Change
5) Enter 0099 and press Done 2 times to return to the Options Menu
6) Press Up Arrow 3 times or until the cursor points to Time/Date and press Show
7) Set the Date and Time to Jan 01 12:00am and press Done
8) Press Goodbye to return to idle screen and verify the Date and time are correct
Before the time changes to 12:01am perform the next step (if the time does change, return to step 7)
9) Press these keys in sequence: Option, Mute, 0 (zero)
Your telephone will reset and the Ad message will be permanently erased.
Hope this helps !
richm is offline
Old 2009-02-06, 09:39 PM   #9
blevine
Wow. Thanks richm. I've been looking for that solution for years now. Great to finally rid that What's New for good.
blevine is offline
Old 2009-02-07, 12:51 PM   #10
Mango
Does anyone know how to do this with a Cybiolink 8000, also from Bell?
Mango is offline
Old 2009-07-22, 08:42 PM   #11
Sniper18
Thanks richm;
The power went out the other day and I noticed the ads came back on the phone. I tried the 1-800 number I originally posted here and noticed it didnt work, so I thought I would find this tread again to ask if anyone found a new one when I found your post.
I am glad you posted these instructions, very helpful!
Sniper18 is offline
Old 2009-08-04, 02:26 PM   #12
SilentLeviathan
If you buy the phone third party the ads are disabled by default.
I purchased a 390 online and a 350 a few years ago at Sears. Neither ever displayed ads.
SilentLeviathan is offline
Old 2011-11-15, 01:40 PM   #13
peterthegreek
Default Get rid of those sevices from vista phones.
To all the people that bought a vista phone and had these sevices with bell, but the numbers don't work when you select them. To get rid of the messages, you have to reset the phone - it will erase numbers, names and call display info. Make sure your clock is set at jan 1 12:00am - either manually set it or unplug your phone for a few min. the press OPTIONS - LINK - # ...this should reset your phone and get rid of those services.
peterthegreek is offline
