Two 9200s. Some questions - Canadian TV, Computing and Home Theatre Forums
Old 2007-08-19, 02:43 PM   #1
iFourm
Question Two 9200s. Some questions
I am building a new house and it has came to the point where I want to wire it for expressvu. I am going to have two hd tvs and two non sd tvs. So my question is if i buy two 9200s will there uhf remotes interfere with each other? If so do you guys have any better ideas to get bev on all of my tvs. Thanks
iFourm is offline
Old 2007-08-19, 02:55 PM   #2
klystron
You can set the remotes to have separate addresses so they will not interfere with each other.
klystron is offline
Old 2007-08-19, 03:01 PM   #3
iFourm
thanks for the quick reply
iFourm is offline
Old 2007-08-19, 03:19 PM   #4
mrhooie
I've got two also. I have both hooked up to the main set and backfeed into the whole house system. I've got one modulated to channel 75 and the other on 85. The modulated signal is combined behind the tva nd one coax run back into the wall outlet that allows me to backfeed it at the house distribution.
Works great. Two UHF remotes upstairs for 2 other tvs and two IR remotes downstairs
I don't run dual mode, I run single mode on each reciever
mrhooie is offline
Old 2007-08-20, 07:50 AM   #5
dosborne
Be sure to run lots of RG6 wiring before the drywall goes on.
dosborne is offline
Old 2007-08-20, 03:51 PM   #6
iFourm
No kidding I spent $700 on cat 5 and rg6. Now i just have to get this house done.
iFourm is offline
Old 2007-08-20, 06:16 PM   #7
i hate tv
I would run 3 rg6 lines to each 9200 location (2 for the 9200 satellite feed, and the other to backfeed, or antenna, or cable, etc...)
if you are ambitious, run your speaker wire too, or even more ambitious, check out the Home Automation forum, and really do some wiring
If the builder will let you do it, I think it is well worth the investment to run as much wiring as possible, just in case...
i hate tv is offline
Old 2007-08-20, 08:52 PM   #8
Nimiq 1
__________
You raise a very valid point about the 3 RG6 lines to each potential 9200 location to account for the back-feed but if there are already 2 cables existing you could Diplex the back-feed into the feed cable.
Just wanted to mention this option.
Nimiq 1 is offline
Old 2007-08-21, 12:16 PM   #9
I_Want_My_HDTV
I use diplexers. They work well and cost about $5-$10 each.
I_Want_My_HDTV is offline
Old 2007-08-21, 01:20 PM   #10
iFourm
Smile
What are diplexers? Btw in my theater room i already have it wired for my projector, speakers, ps3, 360 and 7.2 speakers. I have cat 5 running to every room in the house (two for big rooms. Am i missing anything? dry wall is going up in three days. Thanks for all of your input.
iFourm is offline
Old 2007-08-21, 02:27 PM   #11
i hate tv
A diplexer looks like a 2 way splitter
What it does, is combine the satellite signal going one way, and the TV output signal from the 9200, going the other way, on a single piece of cable
IE : Behind the 9200, you would have a diplexer connected to the cable from your wallplate for example
Then, on the 2 open legs, one would say "SAT" to use a cable to connect to the Satellite input, and the other would say "UHF" (I think) and this would hook up to the OUT TO TV of the 9200
Then, down in your basement, or hydro panel, or wherever your distribution system is, you would have another diplexer, to now separate the 2 signals
The single cable would go into the diplexer, and then you would connect the line from your LNB/multi switch to the "SAT" and then hook up the "UHF" to a spitter to feed the rest of the house (or a single TV if thats all you want)
I hope I havent made this too complicated
Simple way , combine, then seperate 2 signals on a single line, with the signals travelling opposite directions
Old 2007-08-21, 02:29 PM   #12
i hate tv
If you want to put more speakers throughout the house, maybe run some CAT 5 to where you would want to set up a control panel(s) ?
Old 2007-08-21, 02:44 PM   #13
Nimiq 1
__________
Like this;
Nimiq 1 is offline
Old 2007-08-21, 02:59 PM   #14
billw
Default two 9200 new house
I just got finished doing all that. I built a new home and had company do all my structure cabling,security system and surround sound system.
4 Quad sheilded RG6 from outisde location for dish to central area in basement. From there they ran 3 rg6 to great room and 2 master bedroom. 3 to great room, two feed my 9200 and then one to back feed to central area in basement. I then feed it to RG6 to 2nd bedroom and my office. 2 other RG6 went to master bedroom for my 5200.
I also had them do all my rj45 from my newly constructed equipment room. 2 to office, 2 to kitchen and 2 to 2nd bedroom. I have my server and all my router/modem/wireless/telco all in the equipment room with the security system and distribution panel.
here's a pic of the equipment area before/during, I enclosed it into a 5 by 5 room.
http://wragg.servebeer.com/EquipRoom.Jpg
http://wragg.servebeer.com/EquipRoom1.Jpg
billw is offline
Old 2007-08-22, 06:32 AM   #15
I_Want_My_HDTV
Talking
With Dishpro equipment and diplexers, you can replace 3 RG6s with a single RG6 to feed all 3 tuners on a 9200. You can also feed the 2 sat tuners and back feed the RF out from the 9200 with a single RG6.
