LG 50PC5D-Connect to PC VGA Cable or DVI to HDMI Cable? - Canadian TV, Computing and Home Theatre Forums
Old 2007-07-31, 11:34 AM   #1
ryan_lg
Default LG 50PC5D-Connect to PC VGA Cable or DVI to HDMI Cable?
Hi, I just bought an LG 50PC5D Plasma. I want to connect it to my computer, however I`m not sure what connection to use to achieve the best quality. This TV has a VGA input so I could connect my PC using a VGA Cable but my computer also has a DVI Output so I could use a DVI to HDMI cable to connect it to my TV`s second HDMI input. What should I do
Ryan
ryan_lg is offline
Old 2007-07-31, 04:59 PM   #2
fooit
Try both. Check what resolution is supported over VGA and over HDMI.
In theory HDMI should be better, but in real life things maybe different.
fooit is offline
