Other 8300HD Outputs when using HDMI - Canadian TV, Computing and Home Theatre Forums
Old 2007-07-03, 10:30 AM   #1
otown47
Default Other 8300HD Outputs when using HDMI
If your using the HDMI out on an 8300HD, are the other outputs still active...audio and video?
otown47 is offline
Old 2007-07-03, 01:49 PM   #2
Mole
Audio definitely, there are some variations dependent on the settings.
SD Video will work but they, (SA) will not guarantee component at the same time.
"I've sworn off agnosticism, which I now call cowardly atheism" James Cameron
Mole is offline
Old 2007-07-03, 02:30 PM   #3
otown47
Thanks Mole, I wanted a second route from the STB to my AVR so I could treat the music channels differently at the AVR. The RCA jacks would be just fine. I'll give it a try...
otown47 is offline
Old 2007-07-03, 03:30 PM   #4
With the previous firmware, I believe you needed to keep the TV on to keep the handshake between the STB and the TV live (and thereby listen to music). I believe this was fixed with the January firmware, so you should be OK.
57 is offline
