lcd turns green! - Canadian TV, Computing and Home Theatre Forums
Old 2007-06-23, 12:54 PM   #1
RancidUser
Default lcd turns green!
I use my Akai 27" LCT2765TD for bell satellite, pc and my xbox 360. Since playing the "blacksite: area 51" demo on my 360 (through a component connection), the pixels turn green every now and then, not any certain shade, they switch from shade to shade. This does not happen 24/7, but it is very annoying as it makes gaming difficult to concentrate on. It started as I played this new demo for the first time, and as it's abut aliens I thought the screen turning green was just part of the game, but it persisted and still exists.
I have found that if I switch my tv to vga mode and go on the pc for a bit that when I go back to component mode for my 360 the screen is good again...any advice on what may be causing this or a way to stop it?
RancidUser is offline
Old 2007-06-23, 01:01 PM   #2
Poor connections? See the following, especially point 2.
Things to check first.
57 is offline
