Does anyone know if Rogers uncompresses the OTA HD signals it picks up and then compresses them again for distribution thru their system, or do they pass the signals thru as received?????
Thanks... |
I was under the impression OTA signals are sent uncompressed.
Signals sent via cable are definitely compressed and Rogers can alter the compression rate. |
AFAIK, they simply re-modulate the 8VSB signal to a QAM signal. This would leave the MPEG2 Video/Audio untouched.
HD signals are sent OTA and via Rogers cable at 19.4 Mb/sec. No difference. I think satellite is close to this number too - can't remember for sure.
Some stations (PBS Detroit for example) simulcast their SD signal on the "same channel", so their HD "portion" of the signal is slightly lower than the 19.4 Mb/s mentioned above, but they still manage to provide one of the best pictures around. Some US cable companies are considering sending 3 HD channels per 6MHz, but I'm not sure that's been done. This would lower the rate to 12.9 Mb/s. I think they're considering this for the non-rebuilt areas...
#5 | |
Yeah, I noticed that they added something that looked like the Rideau Canal or something recently.
The "Samsung" stuff was done by Randall P. Dark if I recall. As for the PBS comment - when you see the PBS shows on "Over Alaska" or the one on the Antarctic in HD, those really do compare well to Rogers demo. PBS has been showing a lot of upconverted widescreen lately... See the downloadable pdfs for the true HD programmes. http://www.detroitpublictv.org/watch/digitalsched.shtml
#7 | |
#8 | |
There is some new compression coming out that is supposed to do this job without any more artifacts at 12.9, than now at 19.4... Edit, uncompressed HD is over a Gigabit/sec.
#9 |
Thanks for the replies guys, however a lot of this is over my head and maybe I didn't use the right terminology.
What I meant by compressed is the encoding of the original signal into some kind of MPEG signal (like I can do on my computer or is done on a DVD). So if I change the word compressed to encode, does Rogers re-encode the OTA signals. Also are OTA broadcasts encoded MPEG ??? Thanks..... |
#10 | |
Even something as simple as a babbling brook can show pixelation.
To HD - And beyond. |
#11 |
Interestingly, I've been watching a few hours of Basketball and Hockey this past week, and I don't recall seeing any pixellation whatsoever and I have been looking for it.
Same earlier this year on the CBS NCAA games - perfection - and again I was looking for it. I do remember seeing that "flock of birds" example. I think it was in the PBS programme about Kangaroos. I'm wondering if it was the "original" and not what we received, since it's the only example of really bad pixellation I can recall... The only other pixellation I've seen has been minor on movies, or the kind that comes from "missing information" (usually green or white pixels). On the whole, I think the compression chosen has been an excellent compromise, providing an excellent picture the vast majority of the time.
#12 | |
