2 tuner cards? - Canadian TV, Computing and Home Theatre Forums
Old 2007-06-12, 11:41 AM   #1
plummer
Default 2 tuner cards?
Ok.......i got myself a second tuner card.
So now I have Haup PVR150 and a Theater Pro 550.
How does 2 tuner cards work in a system? Do I need a splitter for my cable line that needs to goto both tuner cards? I am not sure.
thanks!
plummer is offline
Old 2007-06-12, 12:16 PM   #2
KingBuzzo
Yes, you would require a signal source for both cards - hopefully you haven't split the cable too many times as it deteriorates as you split.
You didn't mention if you are running Media Center - if you are, you may have to run the mini-setup wizard to recognize the 2nd card - then you are good to go.
KingBuzzo is offline
Old 2007-06-12, 02:04 PM   #3
plummer
yes.....running MCE.
I'll give it a go. Thanks for confirming!
plummer is offline
