D-sub 15 pin?? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > HDTV: Front and Rear Projection Screens and Televisions
Old 2007-06-09, 01:10 PM   #1
Golibano
Default D-sub 15 pin??
I just bought a ViewSonic PJ506D SVGA DLP Projector from TigerDirect and the website says that it will accept component video with a D-sub 15 pin. What is a "D-sub 15 pin" and how do I get the proper cables to use my component video??
Thanks,
J
Golibano is offline
Old 2007-06-10, 01:26 PM   #2
Knight
Premium Supporter
Hi!
That's one of the way to call a VGA-like connector...
The following thread should help you find what you're looking for:
http://www.digitalhome.ca/forum/showthread.php?t=62368
Good luck!
Nick
Knight is online now
Old 2007-06-10, 02:39 PM   #3
Jake
The PJ has a D-sub 15 pin connector (VGA, the familiar 3 rows of pins). You can buy a cable as shown in Post #4 or use a regular YPbPr (component) cable and a small adapter. Most online stores sell the adapter calling it various names but look for 3-RCA to RGB or VGA.
Jake is offline
Old 2007-06-10, 04:01 PM   #4
Bent
I'd think a longer VGA cable with an adapter at the far end from the pj would be more esthetically pleasing.
Bent is offline
