Where do you buy banana plugs? - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Where Can I buy and general buying discussions
Old 2007-05-31, 02:42 PM   #16
timbo
I understand the phobia of using credit cards online.
Plenty of folks use monoprice online and I've never heard a bad word about them.
Check out the Online Retailers Review forum where you will find many opinions of monoprice.
timbo is offline
Old 2007-05-31, 04:58 PM   #17
Plasma1
I bought some banana plugs at Sayal Electronics. They were Philips branded and I think the cost was about $2.00 a pair.This was a single screw model. They are located in Burlington, Missisauga and some other locations. They also had RCA connnectors for RG6 Quad Shield cable for the same price. Check their website.
Plasma1 is offline
Old 2007-05-31, 05:00 PM   #18
magnet
I bought some at MRO Electronics in NE Calgary.
When it comes to humility, I am the greatest!
magnet is offline
Old 2007-06-01, 01:11 PM   #19
d2e8b8
Plasma1, hey Sayal was a great tip. While they have a lousy return policy they had many types of banana plugs at prices that I think are right.
I also like the rest of their store. Actually there are a couple of other electronic stores in the same plaza that I now want to go check out - didn't have much time since I was on my lunch break.
So I bought the banana plugs today at $1 ea and didn't have to use my card online.
d2e8b8 is offline
Old 2008-02-06, 12:05 PM   #20
d2e8b8
Try Sayal Electronics. I bought some banana plugs there (after a kind tip from a fellow DHC'er). I know their location in Mississauga but they also have other locations - google the name for their website.
d2e8b8 is offline
Old 2008-02-06, 05:35 PM   #21
rfielder
If you visit the Sayal store in Mississauga, you will find the strip mall full of electronics retailers that might have what you need. Active is there, and many others.
Another option is Electro Sonic:
http://www.e-sonic.com
rfielder is online now
Old 2008-02-06, 07:32 PM   #22
wallee
Hope this isn't a thread jack as it is semi related.
Has anyone seen component video cables with 90 degree connecters on them?
wallee is offline
Old 2008-02-06, 08:58 PM   #23
fuzzy32
Go to the Audioquest website and look under the "Accessories" tab. Scroll down and you'll find the 90 degreee RCA adapter. This will do the trick.
fuzzy32 is offline
Old 2008-02-06, 10:02 PM   #24
wallee
Thanks Fuzzy
wallee is offline
Old 2009-02-15, 10:46 AM   #25
PBC
Any other places that sell speaker/amp binding posts in Canada? Tried that BC one but keep getting some internet error.
Tx
PBC is offline
Old 2009-02-19, 12:13 PM   #26
d2e8b8
try Sayal Electronics
d2e8b8 is offline
Old 2009-04-07, 12:55 PM   #27
punisher101
You can Banana plug for a very cheap price at mono-price, some people have complained that there not that great.
You can also check Blue Jeans cable probably cheaper to get it from them then Axiom.
punisher101 is offline
Old 2009-04-07, 01:32 PM   #28
...but keep getting some internet error.
This thread is 3 years old - some links die. There are several newer threads on banana plugs if people do a search.
57 is offline
Old 2009-12-01, 06:22 PM   #29
webmonkey8
Question Where can I buy some cheap banana plugs?
Hi,
does anybody know where I can buy some banana plugs which fit 12 gauge speaker wires for a cheap price? Canadian online store preferable.
I've found some but I'm a bit hesitant on this one:
http://www.suntekstore.ca/black-code...-plug-24k.html
Thanks!
webmonkey8 is offline
Old 2009-12-01, 06:49 PM   #30
ctown6412
dealextreme has them for around $11 for 20 pairs when I ordered a few months ago. edit : I take that back, they HAD them but looks like all they stock now are male/female ones that I dont think would work for speaker connections
TBD yet again :)
ctown6412 is offline
