Does anyone know of one?
I'd love to order the GLS locking bananas as advertised on Ebay, but the sole distributor will not mail to Canada. You have to love those Americans that fear mailing to "foreigners". . |
http://www.partsconnexion.com may have something for you depending an how high end you want.
http://www.rpelectronics.com/ Located in Burnaby B.C. Good selection of types, good quality and very reasonably priced. You can order online from web catalogue or phone. I have just bought 14 gold plated for my HT. $6.40 for 2 cdn.
#4 | |
Do any of these plugs require a wrench or hex key to secure the wire, or provide strain relief? Also see this thread. |
#5 | |
#6 | |
Here is a little more definitive information. The item number is 377-501 Dual Banana Plug W Term These are all metal color coded red and black, gold plated plugs two are attached together with a plastic colored Red or Black bridge so that they cannot touch or short. The speaker wire is attached through a hole which is torqued down by a thumb screw at the top end of each plug. The result looks very professional. This item is not listed in their on line catalogue, however it is stocked and can be ordered by phone using the above item number. I assume it is a new item. |
#7 | |
I do not like this construction much because I have found the thumb screw easily works loose, and I do not find that the plug itself is securely held in the socket. Part of the problem can be addressed by attaching the wire to the plug parallel to the midline as described in this article at www.avsforum.com. There is also a picture that is helpful to understand the text. I am looking for a better mechanical connection between the plug and wire, and the plug and socket, hence my earlier questions. |
#8 | |
On the other hand, the left hand side speaker was left with the wire passing transverse to the plug through the big hole, and torqued down with the screw at the end. Last night I was recalibrating the preamp settings after getting a new center speaker, and discovered that I had to reduce the right hand speaker volume by 3-4 dB to equalise the volume with the left hand speaker. I couldn't figure it out at first, and only this morning did I realise that it must be because of the reconfigured banana plug. The conclusion is that you will get a superior wire-to-plug connection using the inline method than the transverse method of connection when using plugs with this configuration. |
#9 |
Location: Thornhill, Rogers, SA3250, Sanyo PLV-Z4, Carada 102", Panny RP56 DVD, HKAVR525, Klipsch, MX700
Did you try the supplier direct? Ie Orange County Speaker at http://www.speakerrepair.com/index.html Call them - 1-800-897-8373. Last email address I have is Bryan@SpeakerRepair.com
I ordered mine from them about tow years back - shipped to Thornhill, Ontario - no problem. They are realy super nice quality. I went for the non-locking variety , I think these are them : http://www.speakerrepair.com/Merchan...ode=AHH_Banana At the time I shared concerns of some about accidentally pulling on the wire and doing some serious damage, So mine just slide snuggly nicely in and out. In fact did once accidentally yank the wrong wire and pulled the plugs out at the receiver end so I was kinda glad I didnt have the locking type and also yank the unit off the shelf onto the hardwood floor. But I cant say for sure how the locking ones would have held as I never tried them. Anyway its a very nice product line. Marvin |
#10 |
#11 |
ok, I never thought it would be so hard to find locking (screw type0 banana plugs at a reasonable price.
A good explanation here - http://www.bluejeanscable.com/store/...ermination.pdf Anyone know of a place where I can buy reasonably decent locking type banana plugs (preferably 2 screws) at about $5 / pair or less in Missisauga/ Brampton/ Oakville. I prefer not to buy US online sites. |
#12 |
The Source by Ciruit City (Radio Shack) sells banana plugs. I hope they have something that you can use.
#13 |
Monoprice has excellent b-plugs. A month ago I ordered 5 pairs for 1.78 USD each and a week later got a small package in my mailbox. It's easier and cheaper then go to TheSource/RadioShack.
WBR, Victor. |
#14 |
Yup Mononprice all the way. And the more you buy, the cheaper they get
#15 |
Thanks for the replies. I should mention that I tried The source and all they had was compression type or solder type. FS/BB had very expensive stuff.
Monoprice seems to have what I need. I think Prod id 2943 will work for me. Now I just have to overcome my phobia of using my credit card online. You see I don't really buy online if I can help it (I know - it probably doesn't make sense in this day and age but ...). |
