buy your own box?? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Other Canadian Cable and IPTV Providers > Access Communications
Old 2007-05-25, 01:23 PM   #1
zky
Default buy your own box??
hi.
access has a waiting list for their hd boxes in the hundreds. If I was to buy my own 6412, would it work through their system?? One lady said no, one lady said
it may work but it may fry the box, and one guy said it should work.
Does anyone have knowledge of this??
zky is offline
Old 2007-05-27, 01:05 AM   #2
BillMinRegina
It would only work if the 6412 was one originally issued to a customer by Access Communications without an outstanding balance owing, or previously reported as stolen. Cable boxes like cell phones are locked to the provider that sold them originally.
Bill McMinn
BillMinRegina is offline
Old 2007-05-28, 09:11 PM   #3
GGopher
There are a number of boxes (6412/6416) available on Ebay. With Shaw you are able to add them on (you have to twist their arm).
GGopher is offline
Old 2007-05-28, 11:49 PM   #4
A bit of a warning. What works on Shaw (activating an outside STB), may not work with another service provider. Also, a STB that works on one service provider may not work on another.
Even with Shaw, the procedure is not always straight forward, as evidenced by the following thread. You'll need to check with a second level technician at Access and then get it in writing along with the compatibile make, model and sub-model numbers.
http://www.digitalhome.ca/forum/showthread.php?t=26417
57 is offline
Old 2007-05-30, 08:48 PM   #5
Neild
I've gotten conflicting info on this over time. One person there said it was 'impossible', another said possible but difficult. Recently a newer tech person said it was possible & easy... but he also said a big supply of boxes had just arrived/was arriving so it wasn't going to be an issue.
Neild is online now
Old 2008-01-22, 10:56 PM   #6
seventieslord
You can definitely do it with Access. I bought two DCT6412 boxes that both came from Comcast in the USA, and it took a few phone calls and some arm twisting but they activated both of them. We all know you need the serial number to activate it, but what a lot of people don't know is that you need the UI number (i think it was called that) for them to first add it to their inventory. This is found on a sitkcer at the bottom. They do NOT need to physically take your box for a week to be able to do this, no matter what they say. Buy your box knowing it will work, download access' firmware using the directions online, and then call access and don't take no for an answer. Just from reading my post you will know more than the first person to answer your call will know - trust me. I've talked to ten of them.
seventieslord is offline
Old 2008-01-25, 11:33 PM   #7
roflskeet
I work for access, It can be done you just need to bring the box in (safest way) to upgrade to our firmware. It HAS to be the exact same box we use or else it will not work and we don't guarantee that it won't brick your box so buyer beware I guess
roflskeet is offline
Old 2008-01-26, 03:54 PM   #8
seventieslord
Yes, it does have to be one of the boxes access uses, for this to work. Aside from that, everything I said above stands.
