Eastlink purchases Persona (to become a nation-wide cable co.) - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > EastLink
Old 2007-05-04, 01:07 PM   #1
digital_rookie
Location: Toronto, Rogers Cable Sony 50" SXRD, SA8300HD 320 GB, SA8300 SD , 2 x SA 3200
Default Eastlink purchases Persona (to become a nation-wide cable co.)
Eastlink's parent company (Bragg Communications Inc.) just bought Persona.
See attached Newswire Link:
http://www.newswire.ca/en/releases/a.../04/c5096.html
digital_rookie is offline
Old 2007-05-05, 10:33 AM   #2
denben73
Oh boy.....
How long are we going to have to wait for new stuff now???? 1...2.. maybe 3 years. I've always had the feeling that it would be sold soon but I wouldn't have thought it would have gone to them. I figured Shaw for the West systems, Cogeco for ON/QC and Rogers would take the NL ones.
denben73 is online now
Old 2007-05-05, 11:19 AM   #3
SensualPoet
Location: Downtown Toronto • Toshiba 52XL177 • HD DVD Toshiba • Rogers HDPVR Cisco 8642
This is hardly the last of the consolidations in the industry. Be patient.
SensualPoet is offline
Old 2007-05-05, 01:19 PM   #4
stampeder
Default Nation wide patchwork of cable TV, internet, other services
As usual, this is subject to CRTC and other regulatory approval.
This gives them a network of local cable providers across the country that fill gaps in the Rogers, Shaw, and Videotron core regions. My guess is that they'll drop the "Eastlink" product name as being too regional and switch it all under the "Persona" banner.
stampeder is offline
Old 2007-05-06, 01:36 AM   #5
denben73
stampeder...
I could see that happening as in Eastlink becoming "Persona".
When I was growing up in NB, I watched all upgrades, channel additions and new services get put on hold while Cable 2000 in Northeastern NB and Cable Service Ltd. in Moncton (how's that for some old forgotten names)were gobbled up by Fundy Cable, then it went to Shaw and now to Rogers. This all happened from 1994-2000.
The last I heard (May 2nd) was they are currently upgrading in Timmins to go to 750 Mhz. We "should" have an much expanded SD line-up (to match Sudbury) in the fall of this year and HD at the beginning of 2008. I'm not trying to be negative but I've been through this stuff a few times to know that I can probably forget about seeing anything new for at least a year. But why upgrade to 750Mhz now then turn around and go to 860Mhz in a couple of years. It seems like alot of work and time just to start all over again.
Old 2007-05-06, 09:05 AM   #6
SensualPoet
A well-managed network at 750 MHz will not need to be upgraded to 860 MHz once Switched Broadcast Video (SBV) is rolled out. It's in extended trial use by Comcast and the final specs are being worked out by manufacturers and cable consortiums. Second, analog spectrum can be repatriated leaving significantly more room in that cable 750 MHz space.
Neither of these activities requiring string more cable, changing repeaters on the street or set-top boxes at the end-user. It would surprise me if SBV isn't in trial by one of Rogers, Shaw, Cogeco or Videotron within 2007 and a "product" sometime in 2008.
The Persona network will be a challenge to operate being so geographically spread-out. Cable is efficient in concentrate (marketing dollars, engineering, head-ends, network support including infrastructure); making Delta, BC as robust as Halifax, NS without duplicating facilities is very hard.
Old 2007-05-06, 03:14 PM   #7
stampeder
Persona bought a state-of-the-art system in Delta Cable, so maybe your comment is the other way around or I misunderstood?
Old 2007-05-06, 06:35 PM   #8
ARR
Smile Glad you liked it!
I configured and shipped all the IRT's, MPS's & RPD's for them.
They had Shaw build it and then operate it on Shaw's DAC for a while.
Same with Coast Cable.
I hear Gordie retired?
Persona could always just build a couple of regional superheadends and then fibre trunk the signals out to each system.
Shaw did that from the Okanagan for the entire B.C. interior.
This way you get consistent signals and lineup and reduced cost and can concentrate your engineering expertise.
ARR is offline
Old 2007-05-06, 07:07 PM   #9
SensualPoet
The challenge is the systems are in Delta BC, Timmins ON, Halifax NS, somewhere in NL ... and all point between. It would be spiffy to connect everyone on one fibre ... but expensive with relatively few customers at each head-end.
I doubt the CRTC would object to the merger/buyout provider the presented business plan sounds half-ways reasonable.
Frankly, it sounds like a nice morsel to gobble up in a year or two when further industry consolidations occur.
Old 2007-05-07, 01:47 PM   #10
ARR
I'm sure Ted and Jim and sharpening up the carving knives and checking the bank balance.
ARR is offline
Old 2007-05-12, 12:07 PM   #11
couch3
just get HD and center ice in timmins already
I'm not gettin any younger
couch3 is offline
Old 2007-05-20, 09:56 PM   #12
Batman
This is all about local telephone...
Batman is offline
Old 2007-09-26, 11:53 AM   #13
denben73
Default It's approved...
Well, the sale to Eastlink has been approved. (That didn't take very long...what's up with that. The CRTC actually being quick??)
Hopefully, we'll see some changes up here....soon!
http://www.crtc.gc.ca/archive/ENG/De...db2007-356.htm
Old 2008-05-28, 06:49 PM   #14
Quadratic
About consolidations, I doubt EastLink will fall to Rogers any time soon. Bragg Communications has a habit of holding on to their companies and playing as the underdog. Plus, with their recent capture of nearly all of NS and NF's government contracts from Bell/Aliant, things are really looking up for them.
Also, Rogers and EastLink have a lot of competitive agreements and partnerships. In many ways it's to Roger's advantage to leave EastLink alone, and turn EastLink vs Aliant into a proxy war between Rogers and Bell, throwing EastLink customers 15% discounts on Rogers cell phone plans, for example.
Quadratic is offline
