I am runiing a 9200, with sw44 switch. Trying to get signal better, I am on transponder 13 and sat.91, I can only get 55%. If I go through all of the transponders the even ones give me 80% + and the odd ones 50-60%. Could it be my switch or lnb?
Thanks |
probably just you
they are tricky to aim, if you dont have the right tools, you could be there for a while It could be the switch, the cable, the LNB, the power inserter... Was the dish already aimed/mounted, or did you mount it yourself? |
Its been up for a year, just started doing it for the last couple of weeks
are there trees in the way, that are now getting leaves?
check the connectors if possible it is possible too that the dish needs reallignment |
I think alignment and obstructions would affect either polarity somewhat equally.
That said, 1 polarity of the switch or LNB would be highly suspect. Try swapping the 2 LNB lines to the switch and see if the problem changes to the other polarity. |
or a shorted connector, or a connector with water damage
tons of possibilities when trying to diagnose over a forum 9200's are picky enough on their own, so i would suggest calling a professional instead of wasting your time trying to figure out what the issue is so every even transponder is over at least 80% ? try ARR's suggestions if you can access the dish switch |
I switched Lnb's around and everything on 91 sat is good, everything on 82 is 40%-0, I did a check switch and everything checked out good exept for line 2 on 82, said reception is poor.
So you started with 1 bad polarity on 91 and after switching LNB's you now have 1 bad polarity on 82.
That pretty much says the switch wasn't the problem. I presume you left the cables in position, so that basically says 1/2 the LNB is bad. Not that you need to, but transposing the 2 82 cables on the switch OR LNB and moving the problem to the other polarity would confirm it. Good job and it looks like I had it 1/2 right. I've got 19 LNB's across 10 dishes here with 9 different switches. It happens on occasion. |
