Ok here it I go... Have a new HD 9200 hooked up to a Panisonic 56" HD both component and through the DVI ports the first night I had this it did not say "NORMAL" when i went to the hi def ... now it says "normal" on every hi def channle any hints to "Y"
I have a sw 44 installed all green with 80+ on all inputs
Normal indicates the "stretch" mode you're currently using. Normal being none. If you press your '*' button on the remote repeatedly, you will cycle through the various stretch modes available. Many people prefer to stretch (or zoom) the SD channels, and leave the HD channels Normal. Personally I prefer Partial Zoom for SD.
By the way, I'm not sure why you're using both DVI and component inputs. You only need one or the other. -Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub |
Thanks I thought I lost the HD feed. The reason I was running both was for testing comparison. This is a site I will stay with. Ligit dish rocks long live 302 after 11pm.
on my TV, on "normal" HD feed is squished to 4x3. On "Full" is normal. Software people don't understand TV.
