Issues with Sirius 12v Adapters - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Entertainment > SiriusXM Satellite Radio
Old 2007-04-12, 10:53 AM   #1
mctnguy
Default Issues with Sirius 12v Adapters
Anyone familiar with a known issue with the Sirius 12v Adapters included with the newer units??
mctnguy is offline
Old 2007-04-12, 11:33 AM   #2
jwt873
The 12 Volt adapters for the newer units (Sportster 3 and 4, Starmate 3 and 4, the Stratus, InV and Stiletto) drop the 12 volts down to 5 volts. There is a switching voltage regulator built inside the plug that fits in the cigarette lighter socket.
They are different from the plugs used for earlier receivers. They used 12 volts instead of 5. The 5 volt adapters have a different sized radio plug so you can't mix them up by accident.
I have two new receivers and the adapters work OK for me. I haven't heard of any failing, so they seem to be dependable.
The only 'problem' you can run into is if you want to keep your cigarette lighter socket free by hard wiring your Sirius receiver under the dash. With the 12 volt receivers, you could snip off the lighter plug and tap into any hot wire. But with the new units, you have to install another lighter socket under the dash use the whole power plug because that's the only way to get the 5 volts. Or, you have to buy an external 12->5 volt reducer with the proper connector to fit your Sirius receiver...... It's a bit more work.
jwt873 is offline
Old 2007-04-12, 09:07 PM   #3
mrhooie
Issues? there were 3000 bad CLAs in current gen units. If your tip has broken off, see the place you bought it for a warrantee replacement
mrhooie is offline
Old 2007-04-13, 01:53 PM   #4
siriusdude
Or just call the call center. They have individual ones to send out (they're out now but more expected any day) and I have a bunch here in the office. If you need one just PM me your information.
Mark
siriusdude is offline
Old 2007-04-14, 01:09 AM   #5
turbo1
I had two returned to my place of work today, we just replaced them. its a knowin issue for sure.
turbo1 is offline
Old 2007-05-07, 04:55 PM   #6
mctnguy
Well, the replacement adapter that they sent me didn't work either. So I brought the whole thing back to the store and canceled my account. I'm still waiting for the refund. The people that I spoke with at sirius were really friendly, but they (sirius) don't have their act together.
I'm really disappointed with them.
mctnguy is offline
Old 2007-09-18, 08:12 PM   #7
96stangr
my 12v adapter for my stiletto after 6 months one day decided to overheat while i was out of my truck, i got in and there was a haze in the cab, i thought i had wiring shorting out under my dash but i looked down and saw the smoke coming from the part that plugs in the dash, i grabbed it quick and pulled it out and it was extremely hot to the touch, took it into best buy and no questions asked gave me a new one right of the box from a new unit. I just hope the new adapter doesn't do the same some day when i'm out of the cab for a couple hours...
96stangr is offline
