#331 |
Im two days into my outdoor modem experiment and all is going extremely well. Im still averaging around 2mbps down and about 250kbps down. I can even use xbox live and play nhl09 which i could never do before. From what i can tell i didnt get any software from rogers just the virus protection stuff but once i put the cd in i'll know for sure then.
#332 |
I have a weird problem, my modem receive 4 lights signal but, I don't have internet access !! No ip is given by the transmision tower !
The tower is located at 29.7 km away from my home. Solution? |
#333 | |
You have to be registered with Rogers: http://www.hispeed.rogers.com/bband/...yourusage.html |
#334 | |
"http://www.softpedia.com/get/Network-Tools/Bandwidth-Tools/NetMeter.shtml" |
#335 |
Well, I went out a bought a Portable modem(indoor) to try where we live. We are probably 6km from the tower directly. Also, my parents live next door, and we wanted to figure out a way to share the internet.
The only signal we could get was from the top of their driveway(they live on one side of the hill, we live on the other, with the tower on their side) After finding out that we had a signal(1, 2 and sometimes 3 bars, depending on where it was placed...very touchy) I went out a purchased a belkin wireless d mimo router. This morning we erected a tv tower in between our houses at the top of the hill, and created a plexiglass housing for both the modem and router. We also put in ventilation holes, and at the bottom an opening with rubber slits to place the power cord in to plug everything in. So up the tower it is, with extension cords running across our property. Now, the only problem is, that we can get a signal from both houses, but very low signals. The modem has only one bar, sometimes 2. When I first tried a couple of nights ago, I had sometimes 3 bars and 1.8mbps down, now I am lucky to get 0.5mbps down.(with one bar, sometimes 2) Do you think it would improve with an outdoor modem?(was thinking it had the same antenna, just a weather proofed case) Or any ideas on how to get another bar or two? Last edited by sugarfly; 2009-04-19 at 08:24 PM. |
#336 |
The External Modem is $249, if you do not activate it you can always send it back and get a full refund. I would say get one and try it.
#337 |
Suagrfly i would get the outdoor modem as you will more than likely get a much better signal. I had similar problems when i tried the indoor modem. I would get 1 or 2 or 3 bars even though there is tower less than 8km away. Now, with the outdoor modem, i have five bars and am averaging more than 2.5mbps down and 250kbps down. I have even hit 3.9mbps down. I just hope it continues to work as well as it has so i can cancel my satellite by the end of next week. (need to give 30 days) I've tried the netmeter and it only allows me to track the computer its installed on. I need something that can track my entire wireless network (pc, 2 laptops, ps3, 360, wii, iphones and everyone who uses it when they come over). Havent found nothing yet. Anyone that knows of something can do this please let me know.
#338 | |
Hack that sucker and add a external antenna ...... Your first mistake was a belkin router. No Offence......should have got a linksys wrt54gl.......flashed it with Tomato firmware which would increase the output from 42 milliwats up to 250 and adding a 9Dbi dipole to the router which both you and you're parents could access/ I'm kinda a WiFi nut... My network consists of 3 routers two of which are 800 feet apart talking to eachother in WDS mode supplying a good friend with internet. It's really easy to hack these modems and remove the internel antenna adding a N Male to RP SMA Male 195 Cable, 1 feet (0.304 meter) the shorter the cable the less signal loss. I'll post a picture in my album showing the WiFi Access Point @ my place. What model and version of Belkin did you purchase... Last edited by gexgeko; 2009-04-21 at 09:31 PM. Reason: Maybe you can put DDwrt Firmware on that Router.. |
#339 |
Wii360 Quote
Suagrfly i would get the outdoor modem as you will more than likely get a much better signal. I had similar problems when i tried the indoor modem. I would get 1 or 2 or 3 bars even though there is tower less than 8km away. Now, with the outdoor modem, i have five bars and am averaging more than 2.5mbps down and 250kbps down. I have even hit 3.9mbps down. I just hope it continues to work as well as it has so i can cancel my satellite by the end of next week. (need to give 30 days) I've tried the netmeter and it only allows me to track the computer its installed on. I need something that can track my entire wireless network (pc, 2 laptops, ps3, 360, wii, iphones and everyone who uses it when they come over). Havent found nothing yet. Anyone that knows of something can do this please let me know. What Router do you have? Make and model. I kinda Screwed that up Didn't I.....lol Last edited by gexgeko; 2009-04-21 at 09:25 PM. |
#340 |
I just bought a linksys WRT54G2-CA router to replace my old trendnet.
#341 |
I wish Not to get to far off topic here but anyone who is Computer Savy and would like to extend the capabilities of there Router depending on the Make and Model/Version consider flashing the firmware to Tomato or DD-WRT Google it and do you're Research before considering this as it can make a usable Router NON usable if not done correctly but has allot of benefits to many to mention here look for yourself.
I take no resposability for anything a user does or doesn't do. And will answer no questions regarding. Do the homework and see if it's a viable solution or consideration. It works for me. |
#342 |
Just to let everyone know I signed up with satelitte internet so I am selling my Rogers outdoor modem and High gain antenna. Time for spring cleanup!
http://ottawa.**********/c-buy-and-se...AdIdZ123841824 |
#343 | |
and whats you're service like? pings download ect? Oh and do you still have that modem? |
#344 |
Sorry for the delay in my reply. I dont come by here much anymore since I am no longer with rogers but this is a great forum. The hack that I did I thought was fun also.
I am now with Explornet and subsribed to contract as I had too. 512 kbps down and it tests as they claim. the ping is about 900 ms on average. The worst thing for me is that VPN does not work. They force the use of NAT on Hughesnet modem. I would expect this to be an issue for gamers also. Unfortunately I did not find this out until 30 day grace period was over. For the modem I still have it in my basement but I expect it to be gone this weekend. |
#345 |
I'm just curious,
Did you check into Bell Canada's 3G network? I know rogers in Luskville, QC is marginal but Bell says full coverage and signal strength in Luskville, QC. Quote from Bell page "In Quebec, our 3G network is now available to 84.8% of the population." I had HughsNet for close to 4 yrs. I know what you're talking about but from what i remeber VPN will work ....just slow as Mole@sses. I used to turn off there proxy to be able to host worms armageddon games. |
| Tags |
| hsi, rogers, wimax |
