Projector Torture Test: LCD versus DLP - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2003
Old 2003-05-02, 09:02 AM   #1
Phil
Default Projector Torture Test: LCD versus DLP
A very interesting article posted at Extreme Tech.
Phil is offline
Old 2003-05-02, 04:15 PM   #2
JohnnyG
That is certainly interesting, but nobody 'tortures' their projectors like this in real life. It sounds like the LCDs 'failed' due to continous exposure to high heat.
JohnnyG is offline
Old 2003-05-02, 04:18 PM   #3
hugh
I agree but it certainly gives one solid reason for picking one over the other especially in a commercial or educational setting.
hugh is offline
Old 2003-05-02, 04:28 PM   #4
JohnnyG
What if the life span is tripled or more by having the projector run for only 12 hours in a 24 hour day?
With anything even remotely resembling 'normal' use, it's probably far more likely that a fan will fail in either technology or the motor that spins the colour wheel in a DLP projector will fail before the actual panel does.
JohnnyG is offline
