what is better for TV xbox PC gamming?
should i tilt toward lcd or plasma like i want to run lets say a game like supreme commander on the display i want to no will i have a burn in problem with plasma running that type of game or using my xbox would it work or with plasma or would lcd be better can i get a poll going on ppl experiences so i have a bit more knowledge before i make a purchase |
ok can a plasma tv burn it quick with a pc connection being used ok it for long periods of time ?
if i want to be used for pc as much as watching it should get lcd ? i am looking for peoples opinions |
I would suggest checking out the FAQ section since your questions are covered in detail there.
WRT burn-in, if you don't keep any static, high contrast patterns on a plasma for extended periods you will be fine. |
could you plz paot a link i dont see a FAQ section or stickey can you post link plz
thanks for the link
so i guess then if i am planing on running the pc a lot threw the tv i souldnt look at plasma is that what i am reading?
I'd go LCD that's 1080P capable. My son is a gamer (PS3) and the display has been great. No worries about burn-in.
