Problem with blacks on toshiba dlp - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > HDTV: Front and Rear Projection Screens and Televisions
Old 2007-02-20, 05:24 PM   #1
BradMan
Location: Bowmanville, ON. Rogers Cable. SA8300HD & Toshiba 52 HM84
Default Problem with blacks on toshiba dlp
Hi. Recently on my Toshiba 52HM84 I've noticed the dark scenes dont look right. Not sure how to describe it but it looks to saturated or something. I would compare it to the screen on a digital camera when viewed at an angle, almost a a faint glowing appearance. Checked all my settings nothing has been changed. Could this be caused by dust somewhere?
BradMan is offline
Old 2007-02-20, 05:37 PM   #2
If nothing has been changed, perhaps that's the issue? Have a look at:
http://www.digitalhome.ca/forum/showthread.php?t=17713
The Blacks on most non-plasma or CRTs are not as black and can have "dithering", especially if not set up properly.
Please put your location and service provider into your UserCP Profile (location). It often helps us help you. For example are the scenes you're describing from a STB? DVD? HD or SD? Etc?
Here's another thread when you have time.
57 is offline
