#451 |
I'm quite sure its the HDD spinning, not a fan. I find it runs constantly even if the receiver has been "off" for over 12 hrs. Also, I have left the receiver on for over 8 hours of not watching anything (forgot to turn it off), and that 4 hr standby timer did nothing that I could tell. They should be able to modify the S/W to turn off the HDD, why have it running when there are no upcomming timers?
#452 |
Humpty...it may not work the way we'd like to see it but it is of some comfort to know that others are running the same way and I shouldn't panic and pack it up for a replacement that does the same thing. I don't get it but if they want to burn the HDD out sooner, I've got a year warranty. With todays technology, I'm not so sure it would matter if it ran full time or not...they're designed ( a microchip I suspect) to die the day after the warranty. (jk) Thx.
#453 |
This has been covered many times before.
Yes, It stays on ALL the time its plugged in, don't worry about it. If the fan is too noisey, its too hot. Try a cooler loacation. IF it shut down, you wouldn't like the 4 minute boot up time. Then the 8 minute guide download. Try it, Unplug it every night, then plug it in again every time you want to watch TV. You'll decide its a lot easier just to leave it plugged in.
#454 |
Appreciate info Tom...as a newcomer to this excellent forum, I could appreciate the topic had been discussed and although I did search for the symtoms, I may have used the incorrect search wording. The location doesn't get much cooler than where it is right now (under TV on open air stand -beside glass doors - 1 1/2' of snow outside (south of Calgary). Going to let it run-on. Really not that noisy but I was more concerned about the wear & tear. Anyways, moved onto another hopefully minor situation with the 9242unit where it was losing signal and reloading the guide every 5 minutes. A reboot seems to have worked for now and hopefully will remain in place for the last Calgary Flames game today. Thx again.
#455 |
I'm not worried about the HDD running, I've seen many HDDs last 10+ years in systems that read/write 24/7, though I wouldn't count on it
#456 | |
Actually, it is significantly better (at least for older technology) to keep the system running 24/7. Typically, it is the startup/shutdown that "kills" items like HDDs. Although power consumption is higher, longevity is greater. |
#457 |
Thanks for clarifying that, dosborne. I have had the 9242 for just over 2 weeks now and love it. The audio if fine and the video looks great. I wonder if I will start to have issues once the HDD starts to get fragmented.
#458 |
#459 |
Got 2 9242's installed last night. Installer says you can't record 2 programs at the same time which is not correct as I used to have a 9200. I think he has not installed in properly. I am in single mode but when I try to record 2 programs it says "recording in progress". Can anyone help? With my old 9200, I recall there was a coax cable also going from the receiver to the TV. Could this be the problem?
#460 |
As long as both tuners are functioning (ie both have cable feeds from the switch) you can record 2 programs at once
You can use a piece of coax cable, or composite (red/white/yellow) for the 2nd tuner to the tv, and then switch inputs to record to different tuners HD will be your current input (HDMI, DVI, Component?) and the 2nd tuner will be video input .... I like this setup, so I can use my TV's PIP capabilities, but its just personal preferance I guess This is how mine is setup, with a rg6 coax also feeding the rest of the house It sounds like maybe you are trying to record to a tuner that is already recording a program |
#461 |
with my old set up, I could just record the 2 programs by pressing the record button on 2 different programs. with this install that is not working. i was just mentioning the coax as it is the only thing that is different. i'm wondering if the 2 feeds from the dish are working properly
#462 |
Run a checkswitch, and that will tell you if both tuners are functioning
#463 |
can you confirm my understanding... If I have 2 functioning feeds into my 9242, I should be able to record 2 programs at the same time without use of any other cables to the tv, correct?
#464 |
Correct!
-Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub |
#465 |
Shaft - I've merged your threads together. Here is my reponse from your other thread:
The coax out cable to a tv is not required. It must be a menu setting. I have the 9200, both are billed as dual tuners PVRs therefore it must be able to record off both at the same time. In fact, you should be able to record 2xSAT tuners and 1xOTA tuner, which I have done on the 9200. (3 concurrent recordings) Check to ensure both tuners are active (check switch). Single mode should be correct. Also check to see which tuner is set as the default for recording (change to 2 if necessary) - I suspect this is the cause. Can't remember more without going through the menu myself. Maybe someone else will have a unit handy. |
| Tags |
| bell 9242, caller id, mts, problem |
