#391 |
By the way I just did the upgrade program, I never had a problem with my 9200 or 6100 before that, Im hoping i luckout with the 9242 as well. Then again I dont watch a ton of tv like some of you.
#392 |
So far, the 9242 that I just received has been 100% better than any of the 9200s I have had. Faster, no audio drops and quieter. Very impressed so far.
BEV 9242, 6131s | Samsung HL67A750 | Pioneer VSX-919AH-K | Cerwin Vega VE-15s, VE-5C, VE-5M |
#393 |
Is there any way of getting TV1 and TV2 to hookup to 2 separate HDTV's and actual receive the signal in HD or is TV1 the only 1 that can run HDTV?
From reading the manual it looks like just TV1, am I correct on this or is there another way? Thanks for any help or suggestions! |
#394 |
Woke up this morning and my wife turned on the 9242, from Tuner 2 TV, and the above error was on the screen. Selected OK and got picture back and all seems normal.
Is this something I should be concerned about or call Bell about? My receiver is about 3 wks old. Last night we were losing picture on HD, I believe because of the bad weather locally. I hope this is not going to be a repeat of my 9200 horror where I had to get 5, yes 5 replacements for one of my 9200s in just over a year. Thx. |
#395 | |
It is always a good idea to call and report it, particularly on a new unit. It may never come back, but if it does at least you would have a note on your file and some "history" about the problem. This may help getting a replacment if required down the road. |
#396 |
Location: Calgary, just west of the center of the Universe
I have had the same error twice now (2 months) everything seems to work fine - I have not called as it is a rental and easy enough to get replaced.
Am I getting new Sony? |
#397 | |
for 2 HDTV's you'd need 2 differnent recievers. I have 2 so far, need a 3rd soon. IF you want both on the same output, you can use HDMI for one and Component+digital audio for the other. Same program.
#398 |
I heard a few weeks ago that Dish Network/Echostar is coming out with a receiver that will do a 2nd HD output using the ATSC tuner of another TV instead of the current NTSC analog tuner. It will probably be some time before Bell would get this receiver.
#399 |
Well, my wife called and said that no PVR functions work on the receiver. Asked to reset the receiver but have not heard back. Will have to call Bell when I get home I guess but its not looking good.
#400 |
Sounds like your hard drive has gone or is going bad according to that specific error code. That's too bad.
#401 | |
-Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub |
#402 | |
Losing the recordings would be a minor setback compared to being unable to access ANY of the PVR functions
However, although easily done particularly with the info posted, I would be reluctanct to suggest to anyone that they follow "extreme" steps such as these without the express request from a CSR/Tech support person. These commands are not "normal" in the sense that there is no preset menu option and are "hidden" for a reason. That isn't to say they should never be done......but the info should be presented with the disclaimer reinforced. So: Quote:
#403 |
There is a list of compatible Hard Drives for the vip622/92xx receiver's I came across the other day, but can't seem to locate it again. From what I understand the 92xx receivers don't need to marry to the hard drive from virgin state, I believe if you plug them in they will function as they should, although this is just going by what someone else told me and I haven't tried it first hand yet. I'll try and hunt down a list for you, maybe it's easier just to replace the SATA HDD on your own, at least it gives you another option.
#404 |
I don't think BEV technical support will suggest reformatting the hard disk. I guess he'll have to weigh the risk of getting a refurbished receiver, vs. possibly fixing his current one with a simple step.
-Mike
#405 |
Dish Firmware APPROVED disks for DVR ViP622 (BELL 9242)
6L250S0 Maxtor 250 490,234,752 7200 SATA 150; 16 MB 6L320S0 Maxtor 320 625,142,448 7200 SATA 150, 16 MB; seen in 622 7Y250M0 Maxtor 250 490,234,752 7200 8 MB 7Y250P0 Maxtor 250 490,234,752 7200 SATA 150, 8 MB; not seen in 622, but working OK ST3320832SCE Seagate 320 625,142,448 7200 SATA 150/300, 8 MB WD3200JS-57PDB0 WD 320 625,142,448 7200 SATA 150/300, 8 MB; listed in 622 FW WD3200KS-57PDB0 WD 320 625,142,488 7200 SATA 150/300, 16 MB; seen in 622 Here is that list for vip622's which is the same receiver as the 9242 BELL. Last edited by mondoguitar; 2008-03-26 at 01:41 PM. Reason: addition |
| Tags |
| bell 9242, caller id, mts, problem |
