Bell TV 9242 HD PVR Discussion thread - Page 20 - Canadian TV, Computing and Home Theatre Forums
Old 2008-02-05, 03:29 PM   #286
supergenius
Had a friend with the smartcard/reboot problem and he was able to exchange it at FS even though it was activated.
supergenius is offline
Old 2008-02-05, 03:37 PM   #287
Nimiq 1
__________
If you never tell them it is activated, then they might exchange it, otherwise they should refuse.
Nothing to loose by trying.
Nimiq 1 is offline
Old 2008-02-05, 06:30 PM   #288
jmavra
Well just went to FS and they exchanged it for me. And he had no problem with it being already activated.
jmavra is offline
Old 2008-02-05, 06:32 PM   #289
Nimiq 1
__________
Good for you.
Hope you now have a good one.
Nimiq 1 is offline
Old 2008-02-05, 08:14 PM   #290
vmpv
Originally Posted by everfresh View Post
I just had my 9242 installed Friday, I haven't had much problems with audio, though I am plugging my audio via Toslink optical cable directly to my television, into my Sony Bravia KDL46W3000 (Merry XMAS to Me!!!)-DL.
The Toslink optical connection on the Sony KDL46W3000 is output only. It's not an input. This is for outputting digital audio when using the ATSC tuner.
vmpv is offline
Old 2008-02-06, 05:53 AM   #291
sheavysheavy
Default well
After 2 months of perfect operation, the 9242 is missing alot of my pvr recordings now, they are set up but they don't start. Shame.
sheavysheavy is offline
Old 2008-02-07, 12:35 AM   #292
peterhefer1
I posted a couple weeks ago about my 9242 not recording the full program, Over the past two weeks it's only recorded Half of ( American Gladiators on the NBCHE ) 2 times over two weeks, Tonight both , American Idol ( FOXHE ) and Law and Order ( NBCHE ) did the same thing. I've deleted all of my recievers programs set for recording from the PVRs memory and changed them from New programs to Weekly to record on different channels at a new timeslot to see if that affects anything? It's so strange I don't know if it's one of the Tuners or a certain Timeslot as everytime I record the later channel after I realize it's incomplete there isn't a problem.
I'm not using the reciever at all in some of the instances.
peterhefer1 is offline
Old 2008-02-07, 11:20 AM   #293
MaxSteel74
How did they help you fix the sync issue?
re:
oldsaskatoonboy
Default Look at the positive...
Lets look at he positive, at least they fixed my lip sync problem. I will be calling this evening to get a credit on my rental for the next month.
MaxSteel74 is offline
Old 2008-02-08, 11:15 AM   #294
justxavier
peterhefer1, It's good to know I'm not alone. Well, maybe "good" is not the right characterization. A number of recordings lately, both SD and HD have simply stopped about half way through, even though the information indicates the full length of the program.
It is usually the same shows, though a large number of them, including "American Idol", "American Gladiators", "The Biggest Loser", and probably most frustratingly, "Terminator".
So essentially, I have an HD PVR that needs to be baby sat, or I have to record every show twice, and just hope that one of the two makes it to the end. Unfortunately, in my case, the time-shifted recordings often stop too.
I haven't made the call for support yet, but when I get to it, I'll let you know what they have to say.
justxavier is offline
Old 2008-02-08, 11:32 AM   #295
Tom.F.1
a simple reboot fixes that problem
Samsung TV, Pio-Elite AVR, OppoBD, Wharfedale Speakers, Kicker Subs. Bell EVu, DB-4e OTA:)
Tom.F.1 is offline
Old 2008-02-08, 11:33 AM   #296
Archangel
I get the audio dropouts as well. It's definitely one of the most irritating thing with these receivers currently. Having to reboot the reciver is a bit part of what makes it irritating.
Archangel is offline
Old 2008-02-08, 11:50 AM   #297
mot_guy
Are you saying that rebooting the receiver, fixed your audio dropouts issue?
mot_guy is offline
Old 2008-02-08, 11:54 AM   #298
Archangel
No, not at all! It just solves it temporarily until it happens again. It's a redundant process that can happen often some days. One night while watching Futurama on YTV, I ended up resetting the receiver 3 times before the half hour show was over. Other nights, I don't have it at all. It's so randon.
Old 2008-02-08, 12:00 PM   #299
mot_guy
Since rebooting the receiver wasn't helping you, wouldn't it be just easier to hit the back 15 seconds button? The audio portions that I miss are normally there again when I go back and play that section again.
mot_guy is offline
Old 2008-02-08, 12:02 PM   #300
Archangel
Yes but to get the audio back at all. I have to reboot the receiver. In doing that I lose the portion of the show that was on while the receiver was being reset.
Tags
bell 9242, caller id, mts, problem
