Picture stuttering on HD - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable
Old 2007-02-19, 02:36 AM   #1
JBond007
Default Picture stuttering on HD
I have noticed at times while watching HD channels the picture stutters. I have three hd set tops and they all do it. Shaw resets the boxes and they work for awhile. Anyone else?
JBond007 is offline
Old 2007-02-19, 12:04 PM   #2
spitoon
I know it's been mentioned here before so try a search for that problem on these forums.
I've seen it a few times myself and usually simply changing channels away from and HD one, and back, seems to fix it. It might be something about the buffer filling up.
Also, I recall mention of going into the menu and switching the output to 480p for a moment then back to 720 (or 1080) to solve the problem if it persists. You should find that info via the search.
spitoon is offline
Old 2007-02-19, 01:19 PM   #3
If the stutter only occurs occasionally, it may be part of the original signal - I refer to this as judder, instead of stutter, especially when the image is panning. If it happens during static scenes, then that's a different story. See the following thread on Motorola STBs, how to set up, how to check signal, etc.
http://www.digitalhome.ca/forum/showthread.php?t=21274
When you have time:
Please put your location and service provider into your UserCP Profile (location). This often helps us help you.
57 is offline
Forum Sponsor
