Bad Industrial Design - Things that can really irk. - Page 2 - Canadian TV, Computing and Home Theatre Forums
Old 2007-02-04, 04:07 AM   #16
stampeder
Thanks VuMax, I'll give that a try. Nice to know there's a workaround. Maybe I can get my Harmony remote to do all those steps in one command.
stampeder is offline
Old 2007-02-04, 11:18 PM   #17
Susido
I've got a new Hyundai 42" plasma and I realize it's pretty much bottom of the barrel (but a real nice picture). The remote control has no less than 9 buttons on it which are completely non-functional (and listed as such in the manual) and 3 more buttons that are supposed to perform some kind of unknown function (manual explanation is beyond recognition) but don't actually do anything either. How's that for an unimpressive design?
Susido is offline
Old 2007-02-06, 09:18 PM   #18
twinpipes
My pet peeve are glossy TV bezels. Some artsy fartsy guy thought it would be a neat idea to put shinny reflective borders around the TV and now almost everyone is following suite.
Sure it looks cool in the store, but everything reflects off of it and it's distracting! There's a reason TV's have normally had none reflective surfaces for decades! Don't fix it if it ain't broke!
twinpipes is offline
Old 2007-02-06, 11:09 PM   #19
Jake
My truck that only holds 90% of a jug of windshield washer liquid. Even when the thing was bone dry it still wouldn't take an entire container. I always have a partial jug rattling around in the back.
Jake is offline
Old 2007-02-11, 05:34 PM   #20
Hydroaxe
Do receivers with HDMI inputs that don't process any audio from HDMI qualify?
I also have a gripe with any piece of equipment that doesn't have an "Instant Pizza" button. I need pizza at the touch of a button 24/7!
www.thislinkdoesn'twork.com
Hydroaxe is offline
Old 2007-02-11, 07:25 PM   #21
stampeder
My Toshiba HDD DVR died completely after about 3 years, so in the autopsy right after bench testing it for an hour or so to try and fix it I was removing the blazing hot hard drive and discovered that the main cpu was located directly underneath it, with no heat sink or fan.
This wasn't like a computer cpu mind you, but it was very hot nonetheless and they had made the design decision to place the hard drive on top of it. There was lots of room in the case for other scenarios, but in their decision-making they had made a choice that led up to this.
To me it was bad industrial design.
Old 2007-02-11, 07:38 PM   #22
que3jxp
PVRs that don't have a easy swap hard drive so that a customer can customize the thing to their needs.
If Moto and SA (and the rest) built their units so that they were sold with no drive or a very small "standard" drive, it would allow everyone easier access to the hardware as they could either forego the drive/live with what it has. Later, or right away, people could buy a universally swappable drive that more appropriately fit their needs.
With SATA in existance, this is more than doable.
I could also rant about the seemingly total lack of focus in regards to a whole home PVR solution...
que3jxp is offline
Old 2007-02-12, 01:58 PM   #23
wolfman
Default Equipment that doesn't support multiple remote codes
Most equipment these days allows the use of multiple units in the same room, by simply setting up different remote codes for the various units. But Motorola DCT's still don't let you do that. If you want to control more than one, forget it. That is so 1970's....
wolfman is offline
Old 2007-02-12, 04:50 PM   #24
JoeSoap
We recently got a new front loader washer/dryer along with pedestal stands (the higher of two heights that were available). The pedestal stand has a drawer which would make for a good spot to put the soap in. However, the high effeciency soap container is a bit too high to fit in the drawer. I've seen three brands of soap and the containers are all too high to fit in the drawer.
JoeSoap is offline
Old 2007-02-12, 05:46 PM   #25
d2e8b8
The various types of av connections - RF, composite, s-video, component, HDMI (with versions now - some do some types of audio, others don't, etc) plus audio inputs - RCA, coax digital, optical (did I miss any?).
In the past I've used DIN connecters as well.
I realize they're trying to integrate all both audio and video into one connector but I wish they'd done it sooner - how hard would it be to come up with a single av connector to do component plus 5.1-ch audio and get rid of all the other inputs.
No wonder only a small minority of geeks have their equipment optimally connected - I have seen HDTV's connected to the coax out from the STB. In fact, that's how the installer connected mine - most people probably leave it like that because it works and it was done by the 'experts'.
d2e8b8 is offline
Old 2007-02-13, 02:45 AM   #26
JohnA1
Default Design peeves - a "two-fer"
Well, one of my pet peeves is the fact that Motorola made a different power/charger adapter for my Motorola cell phone than for the Motorola bluetooth headset I bought with the phone. Wouldn't it be nice if all of the manufacturers could agree on a standard so that everyone in the family could use the same charger for their various phones, PDAs, music players, gaming equipment and other rechargable devices? USB is a standard, why can't chargers be?
And a second peeve is small print and tiny buttons on remote controls and A/V equipment. I hate having to get my reading glasses and turn on a light just to find the darn "input select" or "mode" or "pause" or "zoom" or some other such button. (or maybe my peeve is just with getting old!)
john a
JohnA1 is offline
Old 2007-02-13, 12:12 PM   #27
Rolando
well maybe not for all remotes but DVD player, front projection and AV receiver remotes should all be visible in the dark. I am sure there are others but I know I bought an HD-DVD player to watch movies and 90% of people got this type of equipment to watch movies in the dark.
How am I supposed to change inputs, volume, play, pause, menu etc if I can't see all the little buttoms.
I can understand not everyone watches TV or listens to CDs in the dark but a high end projector, AV receiver and HD-DVD player I am sure are geared towards this.
Rolando Avendaño
Rolando is offline
Old 2007-02-14, 04:28 PM   #28
scotta
Any equipment that has a remote control with a numeric keypad, but only allows you to enter numbers into settings (such as setting the clock or scheduling a recording) by using the up/down arrows to scroll through the numbers for each digit. The same goes for equipment that has the numeric keypad attached, such as a phone.
scotta is offline
Old 2007-02-14, 05:01 PM   #29
PokerChip
Location: New house and HT, Shaw Gateway + 4 portals, BB50
Over the Xmas holidays, my wife and I were shopping for a new coffee maker.
A certain model labelled with a popular brand (I won't mention which one) was designed as a "coffee to go" kind of machine. In other words, it had two spouts from which coffee was dripping. You could either use one or two of the cups which shipped with the coffe maker.
Only problem is when I went in the next aisle of the store to pick up a couple different mugs (standard thermos coffee mugs one buys for a vehicle), they were all too tall to fit under the spouts. In other words, you were stuck using the same two, rather cheap mugs that come in the box.
Pics of my Home Theatre *Updated May 2013*: http://www.flickr.com/photos/6168808...57626366077975
PokerChip is online now
Old 2007-02-15, 01:22 AM   #30
Nuje
That's actually one of the things that totally sold me on my Motorola Q: The Q and my H605 BT headset and my Oakley Rokr shades all use a mini-USB charger (meaning that all can be charged off the USB port on my computer as well).
But you're right: why all cell manufacturers can't just settle on mini-USB for data and charging is a tough one to figure.
Nuje is offline
